Hardware Selection Help - DC Servo Amplifier
6 years 4 months ago - 6 years 4 months ago #173115 by TheBigLebowski
I am hoping that somebody can help me with selecting a DC Servo amplifier that would fit the goals of my project.
I plan to build this setup on a bench as a learning exercise, I am not sure that I will add it to a machine.
I want to do 2 driven axis
Servo type will be a low power brushed permanent magnet dc with a rotary encoder on it. Probably 80vdc or less.
This is the tricky part, I would prefer to close the loop directly at linux cnc using PID. This means the rotary encoder should ideally be going directly to the mesa, rather than a cascading setup. (loop closed at amplifier w/ amp feeding back linuxcnc) I am not certain if this is even possible, so feel free to correct me if I am wrong.
My understanding is this makes step/dir amps a no go, so I should be looking for either PWM amp or analog input amp.
Any input is appreciated.
Note this is a Repost, I accidentally deleted my first post and the thread disappeared.
Last edit: 6 years 4 months ago by TheBigLebowski.
6 years 4 months ago #173119 by tommylight
Have a look at www.mesanet.com/ under the motion control on the left side menu, plenty to choose from, but most of them use 50 pin header, although i am sure they can be made to work with 25 pin cards, but that should be better left to PCW to confirm.
6 years 4 months ago #173131 by TheBigLebowski
I stared right at those for five minutes and didn't see what I was looking for.
After taking a second look it appears that the 7i40h might be what I am looking for.
Is there any good reason to use something like the 4i27 instead of an anything I/O running softdmc? It seams like the anything I/O is far more flexible.
6 years 4 months ago #173143 by jmelson
Another option is the Pico Systems PWM controller and 2 PWM servo amplifiers.
These can easily do 80 V and up to 20 A peak. The loop is controlled by LinuxCNC PID, so you can use the Calibration menu and Halscope to tune the servo response.
The PWM controller sends a 50 KHz PWM signal and direction to the servo amp.
I have been making this setup since about 2003.
Jon
6 years 4 months ago #173163 by TheBigLebowski
Jon,
I really like the Pico amplifier set up, but I do have a question that maybe you can answer about it. Would it be able to support a dual loop feedback setup with more than 2 axis? This is something I would like to experiment with at some point.
I think 2 axis dual loop would be fine because you could dedicate the 2 "unused" axis on the board to reading just a linear encoders.
My concern with more than 2 axis would be that because the encoder counter and PWM Controller run through separate parallel ports there could be latency issues. I don't know if this is a valid concern or not.
I think I am going to order up one of the pico controllers and a pair of amps regardless, just wondering if you had experimented with this.
6 years 4 months ago #173164 by jmelson
OK, by dual loop, you mean a linear scale plus a shaft encoder (mostly for velocity feedback) on the same axis? Yes, it could do this, the PWM controller has 4 encoder counters, so one PWM controller could handle two axes with 2 encoders/axis.
Multiple PWM controllers can be run on the same parallel port, and they exchange synchronizing signals on that parallel port cable, so the encoders are all sampled within 1 us of each other, even on different boards. We have only tested this up to 8 channels (2 boards).
I have not done the dual feedback myself, but it is all done in HAL, so really doesn't have any specific connection to my boards.
If you later order a second controller board, just let me know you need the "daisy chain" cable, and I will provide it to connect the 2nd board to the 1st.
Jon
Moderators: PCW, jmelson
Time to create page: 0.318 seconds
