Mesa 7i96 - getting limit switch status in python
- cody
11 Jul 2020 22:59 #174338
by cody
Mesa 7i96 - getting limit switch status in python was created by cody
I've fumbled around the LinuxCNC python interface guide for a while trying to find how I can read the status of the limit switches. For example, I want a 1 if a limit switch is pressed and a 0 if it is not pressed.
I ran the s.din command and was able to read the other inputs to my machine (prox switches and other sensors) just not limit switches. I press the limit switch and see the LED light up on the Mesa board, and the limit switches work to home the robot, I just can't figure out how to read whether they are pressed or not.
Does anybody know if this is possible to do?
Thanks in advance!
Cody
Thanks in advance!
Cody
- phillc54
- Thank you received: 2100
12 Jul 2020 03:41 #174351
by phillc54
Replied by phillc54 on topic Mesa 7i96 - getting limit switch status in python
You could try reading the hal pins like joint.0.pos-lim-sw-in joint.0.neg-lim-sw-in etc.
The following user(s) said Thank You: cody
- cody
12 Jul 2020 14:10 #174387
by cody
Replied by cody on topic Mesa 7i96 - getting limit switch status in python
Thanks for pointing me in the right direction! I got it figured out. I've added the python code below to make this work if anybody else is interested
import hal
import time
while 1:
h = hal.component("passthrough")
limitX = hal.get_value("joint.0.home-sw-in")
print(limitX)
time.sleep(0.1)
h.exit()Please Log in or Create an account to join the conversation.
- Thank you received: 2181
12 Jul 2020 18:37 #174413
Replied by cmorley on topic Mesa 7i96 - getting limit switch status in python
linuxcnc.org/docs/2.8/html/gui/GStat.html
specifically
hard-limits-tripped
(returns bool, Python List) - Sent when any hard limit is tripped. bool indicates if any limit is tripped, the list shows all available joint’s current limit values.
specifically
hard-limits-tripped
The following user(s) said Thank You: phillc54, nkp
Time to create page: 1.322 seconds
