7i92/G540/C10/THCAD
1 year 11 months ago #314230 by Robbin
Replied by Robbin on topic 7i92/G540/C10/THCAD
Hi all,
i have a similar question, as above. I want to connect a THCAD to my 7i92.
On the 7i92 i run 2 breakoutboards (see below) however i can't figure out what pinsĀ  i need to connect the thcad to.
How can i find where the encoder pins are connected to?
www.amazon.nl/DollaTek-5-assige-CNC-brea...rivers/dp/B07PNDXZQK
Thanks!
1 year 11 months ago - 1 year 11 months ago #314244 by PCW
Replied by PCW on topic 7i92/G540/C10/THCAD
Unfortunately it would be pretty awkward with those breakouts as the inputs
are slow 12V signals. Even with level shifting I don't know if they could deal
with the ~8KHz signals from the THCAD using the highest divider ratio (128)
The breakout board inputs are activated by grounding so you could try adding
a NPN transistor/small MOSFET to do the level translation from the THCADs ~5V signals
to the 12V required but no guarantees...
A better solution might be to drive the appropriate 7I92 line directly (with maybe a 100 ohm
series resistor for safety)
Last edit: 1 year 11 months ago by PCW.
1 year 11 months ago #314245 by Robbin
should i get another bob? and if so what would you recommend?
1 year 11 months ago - 1 year 11 months ago #314251 by PCW
A CNC4PC C10 (that the OP used) is probably a good choice as its an all 5V BOB.
The following user(s) said Thank You: Robbin
1 year 11 months ago #314254 by Robbin
Great!
just one last silly question: how can i find out to what pins the encoder connects?
i can't find anything about the physical pin numbers in the .ini or .HAL file?
i connected the stepper drivers to wahtever the BOB said and that worked but i feel that this is just luck...
where can i find this?
1 year 11 months ago #314255 by PCW
mesaflash --device 7i92 --addr [card_ip_address] --readhmid
will print the pinout of the currently loaded 7I92 firmware
Moderators: PCW, jmelson
Time to create page: 0.400 seconds
