5i25
24 Jul 2020 16:32 #175678 by jfrahm3310
5i25 was created by jfrahm3310
Is latency still an issue with a card like the 5i25 or is that all taken care of buy the card.
  • Moderator
  • Moderator
24 Jul 2020 16:49 #175683 by tommylight
Replied by tommylight on topic 5i25
Simple version, not as much as for parallel port.
In some cases up to 300000ns should be just fine, although to be on the safe side from the occasional excursions i would not use anything above 100000ns on industrial machines.
For the last 2 or 3 months i am using an old laptop with a Mesa 7i92 Ethernet board with the latency of 170 to 180Kns without issues, daily.
24 Jul 2020 17:31 #175687 by jfrahm3310
Replied by jfrahm3310 on topic 5i25
I'm getting 384000 on the 1ms and 515198 on the 25us on a lenovo think centre i5 core cpu I tried some mods in the bios , single core and some other setting but not much help. I read some stuff about some intel chipsets doing some stuff that is not helpful. I have some older computers I might have to try.
24 Jul 2020 17:36 #175688 by PCW
Replied by PCW on topic 5i25
You might try the 1 ms thread by itself since the base thread is not needed
for Mesa hardware, and a 25 usec base thread may simply be too fast for
your hardware, skewing the 1ms results.
latency-test 1ms 1ms
or
latency-histogram --nobase --sbinsize 1000
  • Moderator
  • Moderator
24 Jul 2020 18:16 #175692 by tommylight
Single core on an i5 will not help, it will just cripple the PC.
Disable hyperthreading, speedstep, anything power saving, modem, anything virtualisation....
Moderators: PCW, jmelson
Time to create page: 0.454 seconds
