( Solved ) Mesa 7i76 encoder problem
- Clive S
- Thank you received: 486
26 Jul 2020 10:29 - 29 Jul 2020 09:47 #175913
by Clive S
( Solved ) Mesa 7i76 encoder problem was created by Clive S
I have a 5i25-7i76 that has been working fine for a few years on a small lathe.
The encoder is a home made disk with 3 slot sensors A+B+Z fed into the TB-3 encoder single ended. The spindle speed has stopped displaying
I have put a scope on the A,B,Z pins on the encoder on TB-3 . They are showing that the square wave pulses are fine including index
I am thinking that the board has gone faulty. I don't need the B pulse so as a test could is it possible to change the firmware so that Z is put on to B. Or could the - Z be used.
Last edit: 29 Jul 2020 09:47 by Clive S.
- OT-CNC
- Thank you received: 75
26 Jul 2020 10:57 #175916
by OT-CNC
Replied by OT-CNC on topic ( Solved ) Mesa 7i76 encoder problem
If you look at the encoder connection in hal meter can you get the leds to change state?
- Thank you received: 7506
26 Jul 2020 10:59 #175918
Replied by tommylight on topic ( Solved ) Mesa 7i76 encoder problem
Did you check the enc-a, enc-b and enc-x with hal show ?
- Clive S
26 Jul 2020 12:06 #175927
by Clive S
only A and B not Z I also don't get a count on Z or any of the things like revs etc
Replied by Clive S on topic ( Solved ) Mesa 7i76 encoder problem
- Clive S
26 Jul 2020 12:08 #175928
by Clive S
Yes Tom it is the index that is not working Ie no counts or revs etc
- Thank you received: 5337
26 Jul 2020 12:12 #175931
Replied by PCW on topic ( Solved ) Mesa 7i76 encoder problem
The index input can clear the count but that's it
Did you check the encoder input-a,input-b and input-index pins in hal?
- Clive S
26 Jul 2020 12:41 #175933
by Clive S
Thanks Peter. This has been running fine for a few years I have not modified any of the files It seems to have just died.
they are wired single ended.
I can see the square wave of all three with a scope. I can see the Z pulse with the scope
Is there a way to prove the Z pulse is working on the TB-3 encoder the spindle speed displays 0 in the pypvc panel
26 Jul 2020 13:01 #175941
The spindle speed is not affected by Z, only A of B
Can you check the input-a, input-b and input-index pins in hal?
- Clive S
26 Jul 2020 13:29 #175946
by Clive S
Do you mean in hal show of the hal file itself
26 Jul 2020 13:31 #175948
in halshow or halscope when linuxcnc is running
Time to create page: 0.817 seconds
