Using a PLC to output motor pulses
- EragonPower
- Thank you received: 4
05 Aug 2020 04:42 #177371
by EragonPower
Using a PLC to output motor pulses was created by EragonPower
Is there a way to output STEP and DIR pulses to control some steppers from Linuxcnc through a PLC?
- Thank you received: 7506
05 Aug 2020 05:14 #177374
Replied by tommylight on topic Using a PLC to output motor pulses
Not sure i understand the question.
LinuxCNC can control steppers so no need for PLC, and LinuxCNC has it's own PLC in the form of classic ladder.
- Mike_Eitel
- Thank you received: 183
05 Aug 2020 06:03 #177381
by Mike_Eitel
Replied by Mike_Eitel on topic Using a PLC to output motor pulses
Linuxcnc can generate dir/pulses via different devices. What you are doing with them is up to you. Question with normal plc is their inputs "speed" Normaly they are debounced in the values of some milli seconds.
Mike
Mike
- Thank you received: 1482
05 Aug 2020 11:42 #177403
Replied by Todd Zuercher on topic Using a PLC to output motor pulses
If you want to for example use Classic ladder to control a step motor for a tool changer you could have the PLC send commands to a stepgen (either hardware or software stepgen.)
Time to create page: 0.466 seconds
