[Solved]7i76e missing field IO with custom firmware
  • drmclem
  • drmclem's Avatar Topic Author
  • New Member
  • New Member
18 Aug 2020 19:28 #178619 by drmclem
Replied by drmclem on topic 7i76e missing field IO with custom firmware
Hi all,
Thanks for all your help - I now have all my old functionality back on the 7i76e.
Missing firmware - yes solved - I had indventently removed both instances of the sserial module (which I hadn't realised were needed for the field IO). Putting one back fixed the problem - and still left me with the required pins for a "TTL" serial.
Here is the snippet if anyone is interested.
IOPortTag & x"00" & StepGenTag & StepGenDirPin,		-- I/O 00	embedded 7I76
		IOPortTag & x"00" & StepGenTag & StepGenStepPin,	-- I/O 01
		IOPortTag & x"01" & StepGenTag & StepGenDirPin,		-- I/O 02
		IOPortTag & x"01" & StepGenTag & StepGenStepPin,	-- I/O 03
		IOPortTag & x"02" & StepGenTag & StepGenDirPin,		-- I/O 04
		IOPortTag & x"02" & StepGenTag & StepGenStepPin,	-- I/O 05
		IOPortTag & x"03" & StepGenTag & StepGenDirPin,		-- I/O 06
		IOPortTag & x"03" & StepGenTag & StepGenStepPin,	-- I/O 07
		IOPortTag & x"00" & NullTag & x"00",					-- I/O 08	replacing stepgen 4
		IOPortTag & x"00" & PWMTag & PWMAOutPin,				-- I/O 09	PWM replacing stepgen 4 Step
		IOPortTag & x"00" & SSerialTag & SSerialTX0Pin, 	-- I/O 10	Is this the Field IO SSerial ?
		IOPortTag & x"00" & SSerialTag & SSerialRX0Pin, 	-- I/O 11	Is this the Field IO SSerial ?
		IOPortTag & x"00" & PktUARTTTag & PktUTDataPin,		-- I/O 12	TX
		IOPortTag & x"00" & PktUARTRTag & PktURDataPin,		-- I/O 13	RX
		IOPortTag & x"00" & QCountTag & x"03",  			  	-- I/O 14
		IOPortTag & x"00" & QCountTag & x"02",    			-- I/O 15
		IOPortTag & x"00" & QCountTag & x"01",    			-- I/O 16
I had a few other odd problems which I'm not sure how they arose - in particular I got SCFIFO errors but only when running the z stepper. But I had the pktuart hal update function on a much slower thread (100ms) than the main servo thread (to try and minimise serial through put). Anyway - moving that function onto the main servo thread seemed to stop that error.
Anayway - all good - on to the next step ....
Moderators: PCW, jmelson
