Mesa Flashing 5i24 error
12 Aug 2020 01:37 #177990 by johnmc1
Mesa Flashing 5i24 error was created by johnmc1
Good Day All,
Have just started to add Linuxcnc to my Matsuura MC-1000V4.
Have not been able to flash the 5i24.
When I received the 5i24 the FPGA FLASH SELECT (W7),
was in the down , backup position.
I moved W7 to the up position as per the manual.
When power was applied the 5i24 monentarily flashed .
Then I tried to flash the 5i24 and the following error occurred.
john@debian:~$ cd Downloads/5i24/
john@debian:~/Downloads/5i24$ ls
configs utils
john@debian:~/Downloads/5i24$ cd configs/hostmot2
john@debian:~/Downloads/5i24/configs/hostmot2$ sudo mesaflash --device 5i24 --verify 5i24_16_svss6_8.bit
[sudo] password for john:
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
Error at 0x1000EA expected: 0x10 but read: 0x0
As I have very limited knowledge,
any help with the problem
will be very much appreciated.
  • Moderator
  • Moderator
12 Aug 2020 02:19 #177998 by tommylight
Replied by tommylight on topic Mesa Flashing 5i24 error
Moved to driver boards.
12 Aug 2020 09:30 #178038 by PCW
Replied by PCW on topic Mesa Flashing 5i24 error
That is the expected result if the loaded firmware was not 5i24_16_svss6_8.bit
if you want to write and verify a new bifile you would:
~/Downloads/5i24/configs/hostmot2$ sudo mesaflash --device 5i24 --write 5i24_16_svss6_8.bit --verify 5i24_16_svss6_8.bit
12 Aug 2020 20:51 #178064 by johnmc1
Replied by johnmc1 on topic Mesa Flashing 5i24 error
Thank you PCW for the quick reply,
With your aid, I have flashed the 5i24 and also printed out the pin outs.
Now the fun starts.
Cheers john
Moderators: PCW, jmelson
Time to create page: 0.573 seconds
