halcmd show doesn't match Mesa readhmid (missing encoders & step generator)
27 Aug 2020 00:45 - 27 Aug 2020 00:47 #179613 by jhandel
I think I asked the wrong question on my previous post... so let me reframe a bit... I created a custom bitfile and installed it (see below) of note it added 8 encoders via a 7i89 an extra step generator (via a standard 5 axis bob) and hopefully a bunch of IO (on said 5 axis bob) for other outputs and a few inputs).
However when I look at hal cmdshow (see below) I do not see anything past the default encoder & step generators of port 0 on the 7i76e.
halcmd show all | grep 7i76
    26  s32   OUT    2098000000  hm2_7i76e.0.0.debug
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-00
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-00-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-01
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-01-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-02
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-02-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-03
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-03-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-04
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-04-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-05
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-05-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-06
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-06-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-07
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-07-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-08
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-08-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-09
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-09-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-10
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-10-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-11
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-11-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-12
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-12-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-13
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-13-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-14
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-14-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-15
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-15-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-16
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-16-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-17
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-17-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-18
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-18-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-19
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-19-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-20
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-20-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-21
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-21-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-22
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-22-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-23
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-23-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-24
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-24-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-25
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-25-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-26
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-26-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-27
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-27-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-28
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-28-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-29
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-29-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-30
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-30-not
    26  bit   OUT         FALSE  hm2_7i76e.0.7i76.0.0.input-31
    26  bit   OUT          TRUE  hm2_7i76e.0.7i76.0.0.input-31-not
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-00
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-01
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-02
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-03
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-04
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-05
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-06
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-07
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-08
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-09
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-10
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-11
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-12
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-13
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-14
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.output-15
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.spindir
    26  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.spinena
    26  float IN              0  hm2_7i76e.0.7i76.0.0.spinout
    26  float IN            -50  hm2_7i76e.0.dpll.01.timer-us
    26  float IN            100  hm2_7i76e.0.dpll.02.timer-us
    26  float IN            100  hm2_7i76e.0.dpll.03.timer-us
    26  float IN            100  hm2_7i76e.0.dpll.04.timer-us
    26  float IN              1  hm2_7i76e.0.dpll.base-freq-khz
    26  u32   OUT    0x0000002A  hm2_7i76e.0.dpll.ddsize
    26  float OUT      31.49437  hm2_7i76e.0.dpll.phase-error-us
    26  u32   IN     0x00400000  hm2_7i76e.0.dpll.plimit
    26  u32   OUT    0x00000018  hm2_7i76e.0.dpll.prescale
    26  u32   IN     0x000007D0  hm2_7i76e.0.dpll.time-const
    26  s32   OUT             0  hm2_7i76e.0.encoder.00.count
    26  s32   OUT             0  hm2_7i76e.0.encoder.00.count-latched
    26  bit   I/O         FALSE  hm2_7i76e.0.encoder.00.index-enable <=> spindle-index-enable
    26  bit   OUT         FALSE  hm2_7i76e.0.encoder.00.input-a
    26  bit   OUT          TRUE  hm2_7i76e.0.encoder.00.input-b
    26  bit   OUT          TRUE  hm2_7i76e.0.encoder.00.input-index
    26  bit   IN          FALSE  hm2_7i76e.0.encoder.00.latch-enable
    26  bit   IN          FALSE  hm2_7i76e.0.encoder.00.latch-polarity
    26  float OUT             0  hm2_7i76e.0.encoder.00.position ==> spindle-revs
    26  float OUT             0  hm2_7i76e.0.encoder.00.position-latched
    26  bit   OUT         FALSE  hm2_7i76e.0.encoder.00.quad-error
    26  bit   IN          FALSE  hm2_7i76e.0.encoder.00.quad-error-enable
    26  s32   OUT             1  hm2_7i76e.0.encoder.00.rawcounts
    26  s32   OUT             1  hm2_7i76e.0.encoder.00.rawlatch
    26  bit   IN          FALSE  hm2_7i76e.0.encoder.00.reset
    26  float OUT             0  hm2_7i76e.0.encoder.00.velocity ==> spindle-vel-fb-rps
    26  float OUT             0  hm2_7i76e.0.encoder.00.velocity-rpm
    26  u32   IN     0x007F2815  hm2_7i76e.0.encoder.muxed-sample-frequency
    26  u32   IN     0x00000000  hm2_7i76e.0.encoder.muxed-skew
    26  s32   IN             -1  hm2_7i76e.0.encoder.timer-number
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.000.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.000.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.001.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.001.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.002.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.002.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.003.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.003.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.004.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.004.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.005.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.005.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.006.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.006.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.007.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.007.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.008.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.008.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.009.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.009.in_not
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.010.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.010.in_not
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.011.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.011.in_not
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.012.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.012.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.012.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.013.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.013.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.013.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.014.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.014.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.014.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.015.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.015.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.015.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.016.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.016.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.016.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.017.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.017.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.017.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.018.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.018.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.018.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.019.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.019.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.019.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.020.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.020.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.020.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.021.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.021.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.021.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.022.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.022.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.022.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.023.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.023.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.023.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.024.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.024.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.024.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.025.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.025.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.025.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.026.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.026.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.026.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.027.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.027.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.027.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.028.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.028.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.028.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.029.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.029.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.029.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.030.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.030.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.030.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.031.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.031.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.031.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.032.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.032.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.032.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.033.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.033.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.033.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.034.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.034.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.035.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.035.in_not
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.036.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.036.in_not
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.037.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.037.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.037.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.038.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.038.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.038.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.039.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.039.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.039.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.040.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.040.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.040.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.041.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.041.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.041.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.042.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.042.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.042.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.043.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.043.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.043.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.044.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.044.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.044.out
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.045.in
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.045.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.045.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.046.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.046.in_not
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.047.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.047.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.047.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.048.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.048.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.048.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.049.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.049.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.049.out
    26  bit   OUT          TRUE  hm2_7i76e.0.gpio.050.in
    26  bit   OUT         FALSE  hm2_7i76e.0.gpio.050.in_not
    26  bit   IN          FALSE  hm2_7i76e.0.gpio.050.out
    26  bit   IN          FALSE  hm2_7i76e.0.led.CR01
    26  bit   IN          FALSE  hm2_7i76e.0.led.CR02
    26  bit   IN          FALSE  hm2_7i76e.0.led.CR03
    26  bit   IN          FALSE  hm2_7i76e.0.led.CR04
    26  bit   OUT         FALSE  hm2_7i76e.0.packet-error
    26  bit   OUT         FALSE  hm2_7i76e.0.packet-error-exceeded
    26  s32   OUT             0  hm2_7i76e.0.packet-error-level
    26  s32   OUT             0  hm2_7i76e.0.read-request.time
    26  s32   OUT        202216  hm2_7i76e.0.read.time
    26  u32   OUT    0x00000000  hm2_7i76e.0.sserial.port-0.fault-count
    26  u32   OUT    0x00000003  hm2_7i76e.0.sserial.port-0.port_state
    26  u32   OUT    0x00000000  hm2_7i76e.0.sserial.port-0.port_state2
    26  u32   OUT    0x00000000  hm2_7i76e.0.sserial.port-0.port_state3
    26  bit   IN           TRUE  hm2_7i76e.0.sserial.port-0.run
    26  bit   IN           TRUE  hm2_7i76e.0.stepgen.00.control-type
    26  s32   OUT             0  hm2_7i76e.0.stepgen.00.counts
    26  float OUT             0  hm2_7i76e.0.stepgen.00.dbg_err_at_match
    26  float OUT             0  hm2_7i76e.0.stepgen.00.dbg_ff_vel
    26  float OUT             0  hm2_7i76e.0.stepgen.00.dbg_pos_minus_prev_cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.00.dbg_s_to_match
    26  s32   OUT             0  hm2_7i76e.0.stepgen.00.dbg_step_rate
    26  float OUT             0  hm2_7i76e.0.stepgen.00.dbg_vel_error
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.00.enable <== x-enable
    26  float IN              0  hm2_7i76e.0.stepgen.00.position-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.00.position-fb ==> x-pos-fb
    26  float IN              0  hm2_7i76e.0.stepgen.00.velocity-cmd <== x-output
    26  float OUT             0  hm2_7i76e.0.stepgen.00.velocity-fb
    26  bit   IN           TRUE  hm2_7i76e.0.stepgen.01.control-type
    26  s32   OUT             0  hm2_7i76e.0.stepgen.01.counts
    26  float OUT             0  hm2_7i76e.0.stepgen.01.dbg_err_at_match
    26  float OUT             0  hm2_7i76e.0.stepgen.01.dbg_ff_vel
    26  float OUT             0  hm2_7i76e.0.stepgen.01.dbg_pos_minus_prev_cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.01.dbg_s_to_match
    26  s32   OUT             0  hm2_7i76e.0.stepgen.01.dbg_step_rate
    26  float OUT             0  hm2_7i76e.0.stepgen.01.dbg_vel_error
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.01.enable <== y-enable
    26  float IN              0  hm2_7i76e.0.stepgen.01.position-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.01.position-fb ==> y-pos-fb
    26  float IN              0  hm2_7i76e.0.stepgen.01.velocity-cmd <== y-output
    26  float OUT             0  hm2_7i76e.0.stepgen.01.velocity-fb
    26  bit   IN           TRUE  hm2_7i76e.0.stepgen.02.control-type
    26  s32   OUT             0  hm2_7i76e.0.stepgen.02.counts
    26  float OUT             0  hm2_7i76e.0.stepgen.02.dbg_err_at_match
    26  float OUT             0  hm2_7i76e.0.stepgen.02.dbg_ff_vel
    26  float OUT             0  hm2_7i76e.0.stepgen.02.dbg_pos_minus_prev_cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.02.dbg_s_to_match
    26  s32   OUT             0  hm2_7i76e.0.stepgen.02.dbg_step_rate
    26  float OUT             0  hm2_7i76e.0.stepgen.02.dbg_vel_error
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.02.enable <== z-enable
    26  float IN              0  hm2_7i76e.0.stepgen.02.position-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.02.position-fb ==> z-pos-fb
    26  float IN              0  hm2_7i76e.0.stepgen.02.velocity-cmd <== z-output
    26  float OUT             0  hm2_7i76e.0.stepgen.02.velocity-fb
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.03.control-type
    26  s32   OUT             0  hm2_7i76e.0.stepgen.03.counts
    26  float OUT             0  hm2_7i76e.0.stepgen.03.dbg_err_at_match
    26  float OUT             0  hm2_7i76e.0.stepgen.03.dbg_ff_vel
    26  float OUT             0  hm2_7i76e.0.stepgen.03.dbg_pos_minus_prev_cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.03.dbg_s_to_match
    26  s32   OUT             0  hm2_7i76e.0.stepgen.03.dbg_step_rate
    26  float OUT             0  hm2_7i76e.0.stepgen.03.dbg_vel_error
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.03.enable
    26  float IN              0  hm2_7i76e.0.stepgen.03.position-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.03.position-fb
    26  float IN              0  hm2_7i76e.0.stepgen.03.velocity-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.03.velocity-fb
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.04.control-type
    26  s32   OUT             0  hm2_7i76e.0.stepgen.04.counts
    26  float OUT             0  hm2_7i76e.0.stepgen.04.dbg_err_at_match
    26  float OUT             0  hm2_7i76e.0.stepgen.04.dbg_ff_vel
    26  float OUT             0  hm2_7i76e.0.stepgen.04.dbg_pos_minus_prev_cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.04.dbg_s_to_match
    26  s32   OUT             0  hm2_7i76e.0.stepgen.04.dbg_step_rate
    26  float OUT             0  hm2_7i76e.0.stepgen.04.dbg_vel_error
    26  bit   IN          FALSE  hm2_7i76e.0.stepgen.04.enable
    26  float IN              0  hm2_7i76e.0.stepgen.04.position-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.04.position-fb
    26  float IN              0  hm2_7i76e.0.stepgen.04.velocity-cmd
    26  float OUT             0  hm2_7i76e.0.stepgen.04.velocity-fb
    26  s32   IN              1  hm2_7i76e.0.stepgen.timer-number
    26  bit   I/O         FALSE  hm2_7i76e.0.watchdog.has_bit
    26  s32   OUT         20398  hm2_7i76e.0.write.time
                         <=> hm2_7i76e.0.encoder.00.index-enable
                         <== hm2_7i76e.0.encoder.00.position
                         <== hm2_7i76e.0.encoder.00.velocity
                         ==> hm2_7i76e.0.stepgen.00.enable
                         ==> hm2_7i76e.0.stepgen.00.velocity-cmd
                         <== hm2_7i76e.0.stepgen.00.position-fb
                         ==> hm2_7i76e.0.stepgen.01.enable
                         ==> hm2_7i76e.0.stepgen.01.velocity-cmd
                         <== hm2_7i76e.0.stepgen.01.position-fb
                         ==> hm2_7i76e.0.stepgen.02.enable
                         ==> hm2_7i76e.0.stepgen.02.velocity-cmd
                         <== hm2_7i76e.0.stepgen.02.position-fb
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.analogin0
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.analogin1
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.analogin2
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.analogin3
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.encmode0
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.encmode1
    26  u32   RO     0x00005440  hm2_7i76e.0.7i76.0.0.fieldvoltage
    26  u32   RW     0x00000001  hm2_7i76e.0.7i76.0.0.hwrevision
    26  u32   RW     0x00000009  hm2_7i76e.0.7i76.0.0.nvbaudrate
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.nvencmode0
    26  u32   RO     0x00000000  hm2_7i76e.0.7i76.0.0.nvencmode1
    26  u32   RO     0x1A000094  hm2_7i76e.0.7i76.0.0.nvunitnumber
    26  u32   RO     0x00000032  hm2_7i76e.0.7i76.0.0.nvwatchdogtimeout
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-00-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-01-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-02-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-03-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-04-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-05-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-06-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-07-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-08-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-09-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-10-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-11-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-12-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-13-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-14-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.output-15-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.spindir-invert
    26  bit   RW          FALSE  hm2_7i76e.0.7i76.0.0.spinena-invert
    26  float RW            100  hm2_7i76e.0.7i76.0.0.spinout-maxlim
    26  float RW              0  hm2_7i76e.0.7i76.0.0.spinout-minlim
    26  float RW            100  hm2_7i76e.0.7i76.0.0.spinout-scalemax
    26  u32   RW     0x0000000E  hm2_7i76e.0.7i76.0.0.swrevision
    26  bit   RW          FALSE  hm2_7i76e.0.encoder.00.counter-mode
    26  bit   RW           TRUE  hm2_7i76e.0.encoder.00.filter
    26  bit   RW          FALSE  hm2_7i76e.0.encoder.00.index-invert
    26  bit   RW          FALSE  hm2_7i76e.0.encoder.00.index-mask
    26  bit   RW          FALSE  hm2_7i76e.0.encoder.00.index-mask-invert
    26  float RW              4  hm2_7i76e.0.encoder.00.scale
    26  bit   RW          FALSE  hm2_7i76e.0.encoder.00.sel0.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.encoder.00.sel0.is_opendrain
    26  float RW            0.5  hm2_7i76e.0.encoder.00.vel-timeout
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.012.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.012.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.012.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.013.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.013.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.013.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.014.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.014.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.014.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.015.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.015.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.015.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.016.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.016.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.016.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.017.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.017.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.017.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.018.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.018.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.018.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.019.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.019.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.019.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.020.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.020.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.020.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.021.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.021.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.021.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.022.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.022.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.022.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.023.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.023.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.023.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.024.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.024.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.024.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.025.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.025.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.025.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.026.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.026.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.026.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.027.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.027.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.027.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.028.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.028.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.028.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.029.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.029.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.029.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.030.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.030.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.030.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.031.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.031.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.031.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.032.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.032.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.032.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.033.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.033.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.033.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.037.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.037.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.037.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.038.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.038.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.038.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.039.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.039.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.039.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.040.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.040.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.040.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.041.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.041.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.041.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.042.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.042.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.042.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.043.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.043.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.043.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.044.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.044.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.044.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.045.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.045.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.045.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.047.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.047.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.047.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.048.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.048.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.048.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.049.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.049.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.049.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.050.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.050.is_opendrain
    26  bit   RW          FALSE  hm2_7i76e.0.gpio.050.is_output
    26  bit   RW          FALSE  hm2_7i76e.0.io_error
    26  s32   RO              1  hm2_7i76e.0.packet-error-decrement
    26  s32   RW              2  hm2_7i76e.0.packet-error-increment
    26  s32   RW             10  hm2_7i76e.0.packet-error-limit
    26  s32   RW             80  hm2_7i76e.0.packet-read-timeout
    26  s32   RW              0  hm2_7i76e.0.read-request.tmax
    26  bit   RO          FALSE  hm2_7i76e.0.read-request.tmax-increased
    26  s32   RW         349786  hm2_7i76e.0.read.tmax
    26  bit   RO          FALSE  hm2_7i76e.0.read.tmax-increased
    26  bit   RW          FALSE  hm2_7i76e.0.sserial.00.tx0.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.sserial.00.tx0.is_opendrain
    26  u32   RW     0x00000001  hm2_7i76e.0.sserial.port-0.fault-dec
    26  u32   RW     0x0000000A  hm2_7i76e.0.sserial.port-0.fault-inc
    26  u32   RW     0x000000C8  hm2_7i76e.0.sserial.port-0.fault-lim
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.00.direction.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.00.direction.is_opendrain
    26  u32   RW     0x00002710  hm2_7i76e.0.stepgen.00.dirhold
    26  u32   RW     0x00002710  hm2_7i76e.0.stepgen.00.dirsetup
    26  float RW           37.5  hm2_7i76e.0.stepgen.00.maxaccel
    26  float RW           1.25  hm2_7i76e.0.stepgen.00.maxvel
    26  float RW            200  hm2_7i76e.0.stepgen.00.position-scale
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.00.step.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.00.step.is_opendrain
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.00.step_type
    26  u32   RW     0x00001388  hm2_7i76e.0.stepgen.00.steplen
    26  u32   RW     0x00001388  hm2_7i76e.0.stepgen.00.stepspace
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.00.table-data-0
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.00.table-data-1
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.00.table-data-2
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.00.table-data-3
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.01.direction.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.01.direction.is_opendrain
    26  u32   RW     0x00002710  hm2_7i76e.0.stepgen.01.dirhold
    26  u32   RW     0x00002710  hm2_7i76e.0.stepgen.01.dirsetup
    26  float RW           37.5  hm2_7i76e.0.stepgen.01.maxaccel
    26  float RW           1.25  hm2_7i76e.0.stepgen.01.maxvel
    26  float RW            200  hm2_7i76e.0.stepgen.01.position-scale
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.01.step.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.01.step.is_opendrain
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.01.step_type
    26  u32   RW     0x00001388  hm2_7i76e.0.stepgen.01.steplen
    26  u32   RW     0x00001388  hm2_7i76e.0.stepgen.01.stepspace
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.01.table-data-0
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.01.table-data-1
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.01.table-data-2
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.01.table-data-3
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.02.direction.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.02.direction.is_opendrain
    26  u32   RW     0x00002710  hm2_7i76e.0.stepgen.02.dirhold
    26  u32   RW     0x00002710  hm2_7i76e.0.stepgen.02.dirsetup
    26  float RW           37.5  hm2_7i76e.0.stepgen.02.maxaccel
    26  float RW           1.25  hm2_7i76e.0.stepgen.02.maxvel
    26  float RW            200  hm2_7i76e.0.stepgen.02.position-scale
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.02.step.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.02.step.is_opendrain
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.02.step_type
    26  u32   RW     0x00001388  hm2_7i76e.0.stepgen.02.steplen
    26  u32   RW     0x00001388  hm2_7i76e.0.stepgen.02.stepspace
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.02.table-data-0
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.02.table-data-1
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.02.table-data-2
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.02.table-data-3
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.03.direction.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.03.direction.is_opendrain
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.03.dirhold
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.03.dirsetup
    26  float RW              1  hm2_7i76e.0.stepgen.03.maxaccel
    26  float RW              0  hm2_7i76e.0.stepgen.03.maxvel
    26  float RW              1  hm2_7i76e.0.stepgen.03.position-scale
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.03.step.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.03.step.is_opendrain
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.03.step_type
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.03.steplen
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.03.stepspace
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.03.table-data-0
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.03.table-data-1
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.03.table-data-2
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.03.table-data-3
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.04.direction.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.04.direction.is_opendrain
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.04.dirhold
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.04.dirsetup
    26  float RW              1  hm2_7i76e.0.stepgen.04.maxaccel
    26  float RW              0  hm2_7i76e.0.stepgen.04.maxvel
    26  float RW              1  hm2_7i76e.0.stepgen.04.position-scale
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.04.step.invert_output
    26  bit   RW          FALSE  hm2_7i76e.0.stepgen.04.step.is_opendrain
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.04.step_type
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.04.steplen
    26  u32   RW     0x00027FF6  hm2_7i76e.0.stepgen.04.stepspace
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.04.table-data-0
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.04.table-data-1
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.04.table-data-2
    26  u32   RW     0x00000000  hm2_7i76e.0.stepgen.04.table-data-3
    26  u32   RW     0x004C4B40  hm2_7i76e.0.watchdog.timeout_ns
    26  s32   RW         109726  hm2_7i76e.0.write.tmax
    26  bit   RO          FALSE  hm2_7i76e.0.write.tmax-increased
 hm2_7i76e.0.encoder.00.sel0.invert_output        hm2_7i76e.0.gpio.046.invert_output
 hm2_7i76e.0.encoder.00.sel0.is_opendrain         hm2_7i76e.0.gpio.046.is_opendrain
 hm2_7i76e.0.sserial.00.tx0.invert_output         hm2_7i76e.0.gpio.010.invert_output
 hm2_7i76e.0.sserial.00.tx0.is_opendrain          hm2_7i76e.0.gpio.010.is_opendrain
 hm2_7i76e.0.stepgen.00.direction.invert_output   hm2_7i76e.0.gpio.000.invert_output
 hm2_7i76e.0.stepgen.00.direction.is_opendrain    hm2_7i76e.0.gpio.000.is_opendrain
 hm2_7i76e.0.stepgen.00.step.invert_output        hm2_7i76e.0.gpio.001.invert_output
 hm2_7i76e.0.stepgen.00.step.is_opendrain         hm2_7i76e.0.gpio.001.is_opendrain
 hm2_7i76e.0.stepgen.01.direction.invert_output   hm2_7i76e.0.gpio.002.invert_output
 hm2_7i76e.0.stepgen.01.direction.is_opendrain    hm2_7i76e.0.gpio.002.is_opendrain
 hm2_7i76e.0.stepgen.01.step.invert_output        hm2_7i76e.0.gpio.003.invert_output
 hm2_7i76e.0.stepgen.01.step.is_opendrain         hm2_7i76e.0.gpio.003.is_opendrain
 hm2_7i76e.0.stepgen.02.direction.invert_output   hm2_7i76e.0.gpio.004.invert_output
 hm2_7i76e.0.stepgen.02.direction.is_opendrain    hm2_7i76e.0.gpio.004.is_opendrain
 hm2_7i76e.0.stepgen.02.step.invert_output        hm2_7i76e.0.gpio.005.invert_output
 hm2_7i76e.0.stepgen.02.step.is_opendrain         hm2_7i76e.0.gpio.005.is_opendrain
 hm2_7i76e.0.stepgen.03.direction.invert_output   hm2_7i76e.0.gpio.006.invert_output
 hm2_7i76e.0.stepgen.03.direction.is_opendrain    hm2_7i76e.0.gpio.006.is_opendrain
 hm2_7i76e.0.stepgen.03.step.invert_output        hm2_7i76e.0.gpio.007.invert_output
 hm2_7i76e.0.stepgen.03.step.is_opendrain         hm2_7i76e.0.gpio.007.is_opendrain
 hm2_7i76e.0.stepgen.04.direction.invert_output   hm2_7i76e.0.gpio.008.invert_output
 hm2_7i76e.0.stepgen.04.direction.is_opendrain    hm2_7i76e.0.gpio.008.is_opendrain
 hm2_7i76e.0.stepgen.04.step.invert_output        hm2_7i76e.0.gpio.009.invert_output
 hm2_7i76e.0.stepgen.04.step.is_opendrain         hm2_7i76e.0.gpio.009.is_opendrain
 00026  7f36cff1475d  562d16ef8b20  YES      1   hm2_7i76e.0.read
 00026  7f36cff146e9  562d16ef8b20  YES      0   hm2_7i76e.0.read-request
 00026  7f36cff14606  562d16ef8b20  YES      1   hm2_7i76e.0.write
                  1 hm2_7i76e.0.read
                 11 hm2_7i76e.0.write
But when I look at mesaflash --readhmid all of the new ports per the bitfile are present
Configuration Name: HOSTMOT2
  BoardName : MESA7I76
  FPGA Size: 16 KGates
  FPGA Pins: 256
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  There are 6 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: MuxedQCount
  There are 10 of MuxedQCount in configuration
  Version: 4
  Registers: 5
  BaseAddress: 3600
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for on-card
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       StepGen          0        Dir/Table2      (Out)
14      1   IOPort       StepGen          0        Step/Table1     (Out)
 2      2   IOPort       StepGen          1        Dir/Table2      (Out)
15      3   IOPort       StepGen          1        Step/Table1     (Out)
 3      4   IOPort       StepGen          2        Dir/Table2      (Out)
16      5   IOPort       StepGen          2        Step/Table1     (Out)
 4      6   IOPort       StepGen          3        Dir/Table2      (Out)
17      7   IOPort       StepGen          3        Step/Table1     (Out)
 5      8   IOPort       StepGen          4        Dir/Table2      (Out)
 6      9   IOPort       StepGen          4        Step/Table1     (Out)
 7     10   IOPort       SSerial          0        TXData1         (Out)
 8     11   IOPort       SSerial          0        RXData1         (In)
 9     12   IOPort       SSerial          0        TXData2         (Out)
10     13   IOPort       SSerial          0        RXData2         (In)
11     14   IOPort       MuxedQCount      4        MuxQ-IDX        (In)
12     15   IOPort       MuxedQCount      4        MuxQ-B          (In)
13     16   IOPort       MuxedQCount      4        MuxQ-A          (In)
IO Connections for P1
 1     17   IOPort       None
14     18   IOPort       None
 2     19   IOPort       None
15     20   IOPort       None
 3     21   IOPort       None
16     22   IOPort       StepGen          5        Step/Table1     (Out)
 4     23   IOPort       None
17     24   IOPort       StepGen          5        Dir/Table2      (Out)
 5     25   IOPort       None
 6     26   IOPort       None
 7     27   IOPort       None
 8     28   IOPort       None
 9     29   IOPort       None
10     30   IOPort       None
11     31   IOPort       None
12     32   IOPort       None
13     33   IOPort       None
IO Connections for P2
 1     34   IOPort       MuxedQCount      0        MuxQ-A          (In)
14     35   IOPort       MuxedQCount      0        MuxQ-B          (In)
 2     36   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
15     37   IOPort       MuxedQCount      1        MuxQ-A          (In)
 3     38   IOPort       MuxedQCount      1        MuxQ-B          (In)
16     39   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
 4     40   IOPort       MuxedQCount      2        MuxQ-A          (In)
17     41   IOPort       MuxedQCount      2        MuxQ-B          (In)
 5     42   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
 6     43   IOPort       MuxedQCount      3        MuxQ-A          (In)
 7     44   IOPort       MuxedQCount      3        MuxQ-B          (In)
 8     45   IOPort       MuxedQCount      3        MuxQ-IDX        (In)
 9     46   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
10     47   IOPort       None
11     48   IOPort       SSerial          0        RXData3         (In)
12     49   IOPort       SSerial          0        TXData3         (Out)
13     50   IOPort       SSerial          0        TXEn3           (Out)
I know the bitfile might be "bad" maybe? so here it is for reference too.. I can understand the pncconf not knowing what all these extra ports on.. but I would have thought the halcmd show would have found them.. especially since there is nothing in the Hal to configure them manually.
library IEEE;
use IEEE.std_logic_1164.all;  -- defines std_logic types
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Copyright (C) 2007, Peter C. Wallace, Mesa Electronics
-- http://www.mesanet.com
-- This program is is licensed under a disjunctive dual license giving you
-- the choice of one of the two following sets of free software/open source
-- licensing terms:
--    * GNU General Public License (GPL), version 2.0 or later
--    * 3-clause BSD License
-- The GNU GPL License:
--     This program is free software; you can redistribute it and/or modify
--     it under the terms of the GNU General Public License as published by
--     the Free Software Foundation; either version 2 of the License, or
--     (at your option) any later version.
--     This program is distributed in the hope that it will be useful,
--     but WITHOUT ANY WARRANTY; without even the implied warranty of
--     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
--     GNU General Public License for more details.
--     You should have received a copy of the GNU General Public License
--     along with this program; if not, write to the Free Software
--     Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301 USA
-- The 3-clause BSD License:
--     Redistribution and use in source and binary forms, with or without
--     modification, are permitted provided that the following conditions
--     are met:
--   * Redistributions of source code must retain the above copyright
--     notice, this list of conditions and the following disclaimer.
--   * Redistributions in binary form must reproduce the above
--     copyright notice, this list of conditions and the following
--     disclaimer in the documentation and/or other materials
--     provided with the distribution.
--   * Neither the name of Mesa Electronics nor the names of its
--     contributors may be used to endorse or promote products
--     derived from this software without specific prior written
--     permission.
-- Disclaimer:
--     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
--     "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
--     LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
--     FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
--     COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
--     INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
--     BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
--     LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
--     CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
--     LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
--     ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
--     POSSIBILITY OF SUCH DAMAGE.
use work.IDROMConst.all;
package PIN_7i76x1_7i89x2D_x15ABOB_51 is
	constant ModuleID : ModuleIDType :=(
		(HM2DPLLTag,	x"00",	ClockLowTag,	x"01",	HM2DPLLBaseRateAddr&PadT,	HM2DPLLNumRegs,		x"00",	HM2DPLLMPBitMask),
		(WatchDogTag,	x"00",	ClockLowTag,	x"01",	WatchDogTimeAddr&PadT,		WatchDogNumRegs,		x"00",	WatchDogMPBitMask),
		(IOPortTag,		x"00",	ClockLowTag,	x"03",	PortAddr&PadT,					IOPortNumRegs,			x"00",	IOPortMPBitMask),
		(StepGenTag,	x"02",	ClockLowTag,	x"06",	StepGenRateAddr&PadT,		StepGenNumRegs,		x"00",	StepGenMPBitMask),
		(MuxedQcountTag,		MQCRev,	ClockLowTag,	x"0A",	MuxedQcounterAddr&PadT,		MuxedQCounterNumRegs,x"00",	MuxedQCounterMPBitMask),
		(MuxedQCountSelTag,	x"00",	ClockLowTag,	x"01",	NullAddr&PadT,					x"00",					x"00",	x"00000000"),
		(SSerialTag,	x"00",	ClockLowTag,	x"01",	SSerialCommandAddr&PadT,	SSerialNumRegs,		x"10",	SSerialMPBitMask),
		(LEDTag,			x"00",	ClockLowTag,	x"01",	LEDAddr&PadT,					LEDNumRegs,				x"00",	LEDMPBitMask),
		(NullTag,				x"00",	NullTag,			x"00",	NullAddr&PadT,					x"00",					x"00",	x"00000000"),
	constant PinDesc : PinDescType :=(
-- 	Base func  sec unit sec func 	sec pin
		IOPortTag & x"00" & StepGenTag & StepGenDirPin,					-- I/O 00	embedded 7I76
		IOPortTag & x"00" & StepGenTag & StepGenStepPin,				-- I/O 01
		IOPortTag & x"01" & StepGenTag & StepGenDirPin,					-- I/O 02
		IOPortTag & x"01" & StepGenTag & StepGenStepPin,				-- I/O 03
		IOPortTag & x"02" & StepGenTag & StepGenDirPin,					-- I/O 04
		IOPortTag & x"02" & StepGenTag & StepGenStepPin,				-- I/O 05
		IOPortTag & x"03" & StepGenTag & StepGenDirPin,					-- I/O 06
		IOPortTag & x"03" & StepGenTag & StepGenStepPin,				-- I/O 07
		IOPortTag & x"04" & StepGenTag & StepGenDirPin,					-- I/O 08
		IOPortTag & x"04" & StepGenTag & StepGenStepPin,				-- I/O 09
		IOPortTag & x"00" & SSerialTag & SSerialTX0Pin, 				-- I/O 10
		IOPortTag & x"00" & SSerialTag & SSerialRX0Pin, 				-- I/O 11
		IOPortTag & x"00" & SSerialTag & SSerialTX1Pin, 				-- I/O 12
		IOPortTag & x"00" & SSerialTag & SSerialRX1Pin, 				-- I/O 13
		IOPortTag & x"04" & MuxedQCountTag & MuxedQCountIDXPin,		-- I/O 14
		IOPortTag & x"04" & MuxedQCountTag & MuxedQCountQBPin,		-- I/O 15
		IOPortTag & x"04" & MuxedQCountTag & MuxedQCountQAPin,		-- I/O 16
																			--		P1
																			-- 5ABOB pinout
																			-- 26 HDR	-- IDC DB25
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 01	PIN 1		PIN 1 	Spindle DAC PWM
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 02   PIN 2		PIN 14	just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 03   PIN 3		PIN 2	   just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 04	PIN 4		PIN 15	just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 05	PIN 5		PIN 3	   just GPIO
		IOPortTag & x"05" & StepGenTag & StepGenStepPin,	-- I/O 06	PIN 6		PIN 16	B2 Step
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 07	PIN 7		PIN 4	   just GPIO
		IOPortTag & x"05" & StepGenTag & StepGenDirPin,		-- I/O 08	PIN 8		PIN 17	B2 Dir
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 09	PIN 9		PIN 5	   just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 10	PIN 11	PIN 6	   just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 11	PIN 13	PIN 7	   just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 12	PIN 15	PIN 8	   just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 13	PIN 17	PIN 9	   just GPIO
		IOPortTag & x"00" & NullTag & NullPin,					-- I/O 14	PIN 19	PIN 10	just GPIO
		IOPortTag & x"00" & NullTag & NullPin,  				-- I/O 15	PIN 21	PIN 11  	just GPIO
		IOPortTag & x"00" & NullTag & NullPin,  				-- I/O 16	PIN 23	PIN 12	just GPIO
		IOPortTag & x"00" & NullTag & NullPin,    			-- I/O 33	PIN 25	PIN 13	just GPIO
																						--		P2			HDR26		DB25
		IOPortTag & x"00" & MuxedQCountTag & MuxedQCountQAPin,		-- I/O 17	PIN 1    PIN 1
		IOPortTag & x"00" & MuxedQCountTag & MuxedQCountQBPin,		-- I/O 18	PIN 14   PIN 2
		IOPortTag & x"00" & MuxedQCountTag & MuxedQCountIDXPin,		-- I/O 19	PIN 2    PIN 3
		IOPortTag & x"01" & MuxedQCountTag & MuxedQCountQAPin,		-- I/O 20	PIN 15   PIN 4
		IOPortTag & x"01" & MuxedQCountTag & MuxedQCountQBPin,		-- I/O 21	PIN 3    PIN 5
		IOPortTag & x"01" & MuxedQCountTag & MuxedQCountIDXPin,		-- I/O 22	PIN 16   PIN 6
		IOPortTag & x"02" & MuxedQCountTag & MuxedQCountQAPin,		-- I/O 23	PIN 4    PIN 7
		IOPortTag & x"02" & MuxedQCountTag & MuxedQCountQBPin,		-- I/O 24	PIN 17   PIN 8
		IOPortTag & x"02" & MuxedQCountTag & MuxedQCountIDXPin,		-- I/O 25	PIN 5    PIN 9
		IOPortTag & x"03" & MuxedQCountTag & MuxedQCountQAPin,		-- I/O 26	PIN 6    PIN 11
		IOPortTag & x"03" & MuxedQCountTag & MuxedQCountQBPin,		-- I/O 27	PIN 7    PIN 13
		IOPortTag & x"03" & MuxedQCountTag & MuxedQCountIDXPin,		-- I/O 28	PIN 8    PIN 15
		IOPortTag & x"00" & MuxedQCountSelTag & MuxedQCountSel0Pin,	-- I/O 29	PIN 9    PIN 17
		IOPortTag & x"00" & NullTag & NullPin,	 	   					-- I/O 30	PIN 10   PIN 19 powop
		IOPortTag & x"00" & SSerialTag & SSerialRX2Pin, 				-- I/O 31	PIN 11   PIN 21
		IOPortTag & x"00" & SSerialTag & SSerialTX2Pin, 				-- I/O 32	PIN 12   PIN 23
		IOPortTag & x"00" & SSerialTag & SSerialTXEN2Pin, 				-- I/O 33	PIN 13   PIN 25
		LIOPortTag & x"00" & SSerialTag & SSerialNTXEn1Pin,
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin, -- added for IDROM v3
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin);
end package PIN_7i76x1_7i89x2D_x15ABOB_51;
Any suggestions on how to at least get the new encoders, step generator and IO pins visible to the hal would be awesome!
Thanks all
Josh
Last edit: 27 Aug 2020 00:47 by jhandel.
27 Aug 2020 01:09 #179617 by PCW
How many stepgens and encoders are enabled in the hal file?
27 Aug 2020 01:47 #179620 by jhandel
so change "num_encoders=1 num_pwmgens=0 num_stepgens=5"
to "num_encoders=2 num_pwmgens=0 num_stepgens=6"
is it really just that easy? (totally missed that line while I was looking at the hal)
I don't need to tell it which ports or which pins those generators are connected to?
Also, how would I use the other pin's as general IO? do I need to do something in the vhd or just do the "nulltag" like I did and then route to the correct hm2_7i76e.0.gpio.XX for the wiring of those pins in the HAL?
(and thanks, the halcmd matches the --readhmid when I made that change)
27 Aug 2020 02:33 - 27 Aug 2020 02:33 #179626 by PCW
All pins can be GPIO if not claimed by an enabled secondary function
(Stepgen, PWMGen etc) pins without a secondary function (nulltag in
secondary function field) are GPIO only
All GPIO pins default to inputs and need to be set to output mode in hal
Secondary function pinouts are hardwired in the configuration
(you cannot change them on th fly)
Last edit: 27 Aug 2020 02:33 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.745 seconds
