- Hardware & Machines
- Driver Boards
- 7i76e all P1 pins are 5v high (except 18 ~25 which are 0v common as expected)
- Thank you received: 5308
04 Sep 2020 18:07 - 04 Sep 2020 18:08 #180724
Replied by PCW on topic 7i76e all P1 pins are 5v high (except 18 ~25 which are 0v common as expected)
If the P1 and P2 I/O pins don't work (and not just one but many) Its possible that you
damaged one or both bus switch chips (FST16211) on the 7I76E
You can check this by carefully measuring the voltage across C11 (for P1) and C68 (or P2)
If these are not close to 4V, the bus chips have been damaged by excessive
input voltage (less than -0.5V without a current limit or greater than 7V)
Last edit: 04 Sep 2020 18:08 by PCW.
- jhandel
- Thank you received: 7
04 Sep 2020 20:30 - 04 Sep 2020 20:31 #180749
by jhandel
Replied by jhandel on topic 7i76e all P1 pins are 5v high (except 18 ~25 which are 0v common as expected)
both mid 40's mv so I'll chalk that up to a "learning" experience
So given that the BOB was never plugged into P2 and P2 was never hit by anything but the 7i89 I am guessing the plugging of it in "hot" last night after the failed test of P1 killed P2...
And I guess my sainsmart cheap bob from 2016 that was collecting dust from a 2018 re-wiring of my CNC-Router might have been bad and somehow killed P1...
yah *jazz hands*
well I can save a whole bank of relays I added by switching to a 7i69ed because all the outputs on my machine sink voltage.. (all my inputs do too but I already have my pullup resistor trick so that is less important)
any suggestion on what to look at to see if the 7i89 is dead too?
yah *jazz hands*
Last edit: 04 Sep 2020 20:31 by jhandel.
04 Sep 2020 21:08 #180757
Its possible that the 7I89 was damaged but can't be sure
The 7I76E is likely repairable by replacing the FST16211s
- jhandel
04 Sep 2020 21:56 #180768
by jhandel
likely true if I could do surface mount soldering.. but that would require a bit of tooling that might cost as much as a new card... I'll have to noodle on what to do now that I have gone and done fowled this up..
- Driver Boards
