picnc to stm32f progress.
05 Sep 2020 23:26 - 05 Sep 2020 23:31 #180873 by mhel
picnc to stm32f progress. was created by mhel
'just wanted to post my progress on porting of picnc to stm32f4. (currently on a f407 but plan to use f405...because price :) )
https://streamable.com/k1ksfg
https://streamable.com/dl61rh
...and some query
I did a hack job with the spi
in the hal module, I'm using spidev
as it's the easiest to search on google
to find help.
I'm getting odd result if I commanded a 0 position.
I could issue a command greater than or less than 0,
e.g. -0.0005 0.0625 and it's ok, but with 0,
I get result like this:
ibb.co/fdyp0DP
Anyone uses/used the picnc and encounter(ed) the same?
I'm using the exact same code from picnc v2 (aka copy paste ;) )
except for the spi communication.
This is running on a tinkerboard, will try rpi3/4 whenever I get my hands on them.
Last edit: 05 Sep 2020 23:31 by mhel. Reason: Forgotten the actual question :)
  • twoflowers
  • twoflowers's Avatar
  • Visitor
  • Visitor
03 Oct 2020 15:16 #184694 by twoflowers
Replied by twoflowers on topic picnc to stm32f progress.
Do you have the code somewhere? I have here a nucleo64 with 446RE what would like to be a test candidate.
03 Oct 2020 22:05 #184740 by mhel
Replied by mhel on topic picnc to stm32f progress.
I'm using this library github.com/andysworkshop/stm32plus
unfortunately it doesn't have support for the 446RE., because of older std pheriperal library.
I'm a C++ newbie but I find it a very good library with lots of examples.
Testing is on pause I got distracted trying to make GUI on a weston wayland, but I think I"m way over my head on that one, not enough skill.
If you are still interested let me know.
  • twoflowers
  • Visitor
  • Visitor
04 Oct 2020 09:04 #184788 by twoflowers
Still interested, but I'm wondering if it would not be easier to use the STM32 arduino core for migration.
04 Oct 2020 19:07 - 05 Oct 2020 13:33 #184865 by mhel
Whew, it took time to create the repo, but I learnt some git.
here it is, I hope you find it useful.
github.com/mhelmarc/stcnc
It would probably be easier with Arduino, but it's been a long time
since I tried to use it. I think the stm32plus is more complete, but
then again the Arduino has more contributor.
Last edit: 05 Oct 2020 13:33 by mhel.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
04 Oct 2020 21:43 #184876 by BeagleBrainz
Replied by BeagleBrainz on topic picnc to stm32f progress.
  • twoflowers
  • Visitor
  • Visitor
05 Oct 2020 10:04 #184954 by twoflowers
Thank you for uploading the code.
debounce(int32_t A) { ... } : This works wit notmally-closed-switches. If jitter is on the line, it might be that a LOW is detected. So it uses 3 samples and only whwn all 3 are LOW (==OPEN), then the resolt is OPEN, otherwise it's CLOSED
05 Oct 2020 13:33 #184965 by mhel
@BeagleBrainz
Thanks, I have just tried that change in stcnc.c and I'm still getting
error when commanding a zero value.
@twoflowers
Now I get it, thanks.
15 Jul 2021 23:32 #214947 by mhel
just to close this. I have a better port here github.com/mhelmarc/Remora-STM32, I've learnt a few tricks on the way there.
Moderators: PCW, jmelson
Time to create page: 0.184 seconds
