Mesa 7i92 Intermittent Read Errors
06 Sep 2020 05:14 - 06 Sep 2020 05:18 #180935 by turretbuddy2
Mesa 7i92 Intermittent Read Errors was created by turretbuddy2
I've checked the other posts on this issue "hm2/hm2_7i92.0: error finishing read!" with no luck so far employing the most straightforward solutions. The machine works fine until it disconnects from the error. Asking for help here before I dive into harder fixes (try new pc, reduce emi). Hal and ini files included!
error behaviour:
-intermittent (showing up after few seconds or hours)
-sometimes restarting the laptop makes the error take longer to show up
-certain restarts get the the error to appear in the first few minutes consistently when launching linuxcnc repeatedly
-the error still occurs when not operating the machine after initialising linuxcnc
solutions tried:
-changing eth cable to shielded
-jostling wires to look for poor connections/noise
-installing proprietary realtek eth drivers r8168
-checking 5v supply
laptop specs:
Release Linux Mint 19.2 Tina 64-bit
Kernel Linux 4.19.106-rt44-lcnc x86_64
CPU:
Topology: Dual Core model: Intel Core i5 M 430 bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 1852 MHz min/max: 1199/2267 MHz Core speeds (MHz): 1: 1862 2: 1862
3: 1862 4: 1862
Network:
Device-1: Broadcom and subsidiaries BCM43225 802.11b/g/n driver: wl
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8168
Servo jitter is 81us (latency test)
halcmd show param *.tmax results:
Parameters:
Owner Type Dir Value Name
32 s32 RW 39938 debounce.0.tmax
26 s32 RW 0 hm2_7i92.0.read-request.tmax
26 s32 RW 1522316 hm2_7i92.0.read.tmax
26 s32 RW 946588 hm2_7i92.0.write.tmax
19 s32 RW 67660 motion-command-handler.tmax
19 s32 RW 119383 motion-controller.tmax
29 s32 RW 47012 pid.s.do-pid-calcs.tmax
29 s32 RW 52144 pid.x.do-pid-calcs.tmax
29 s32 RW 44124 pid.y.do-pid-calcs.tmax
29 s32 RW 49072 pid.z.do-pid-calcs.tmax
20 s32 RW 1656028 servo-thread.tmax
dmesg | tail -50 results:
[ 7.045766] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20180810/utaddress-213)
[ 7.045771] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 7.045773] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20180810/utaddress-213)
[ 7.045778] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 7.045779] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 7.049097] intel ips 0000:00:1f.6: CPU TDP doesn't match expected value (found 25, expected 29)
[ 7.049431] intel ips 0000:00:1f.6: failed to get i915 symbols, graphics turbo disabled until i915 loads
[ 7.049736] intel ips 0000:00:1f.6: IPS driver initialized, MCP temp limit 90
[ 7.553604] input: HP WMI hotkeys as /devices/virtual/input/input16
[ 7.913700] kvm: disabled by bios
[ 7.984707] kvm: disabled by bios
[ 8.041391] kvm: disabled by bios
[ 8.066940] Bluetooth: Core ver 2.22
[ 8.068836] NET: Registered protocol family 31
[ 8.068838] Bluetooth: HCI device and connection manager initialized
[ 8.068846] Bluetooth: HCI socket layer initialized
[ 8.068849] Bluetooth: L2CAP socket layer initialized
[ 8.068865] Bluetooth: SCO socket layer initialized
[ 8.106628] kvm: disabled by bios
[ 8.180980] usbcore: registered new interface driver btusb
[ 8.564106] enp3s0: 0xffffab7640a81000, 00:26:9e:ca:54:7e, IRQ 24
[ 8.639097] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 8.861973] wl 0000:02:00.0 wlo1: renamed from wlan0
[ 8.969873] media: Linux media interface: v0.10
[ 9.005257] videodev: Linux video capture interface: v2.00
[ 9.129347] uvcvideo: Found UVC 1.00 device HP Webcam (064e:a127)
[ 9.174639] uvcvideo 2-1.5:1.0: Entity type for entity Extension 5 was not initialized!
[ 9.174646] uvcvideo 2-1.5:1.0: Entity type for entity Extension 4 was not initialized!
[ 9.174648] uvcvideo 2-1.5:1.0: Entity type for entity Processing 3 was not initialized!
[ 9.174651] uvcvideo 2-1.5:1.0: Entity type for entity Camera 1 was not initialized!
[ 9.201015] input: HP Webcam: HP Webcam as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/input/input17
[ 9.215078] usbcore: registered new interface driver uvcvideo
[ 9.215081] USB Video Class driver (1.1.1)
[ 9.635071] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.635075] Bluetooth: BNEP filters: protocol multicast
[ 9.635083] Bluetooth: BNEP socket layer initialized
[ 9.725630] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 10.703383] r8168: enp3s0: link up
[ 10.703403] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 11.117826] random: crng init done
[ 11.117831] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.123333] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 12.354031] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 15.229821] Bluetooth: RFCOMM TTY layer initialized
[ 15.229833] Bluetooth: RFCOMM socket layer initialized
[ 15.229843] Bluetooth: RFCOMM ver 1.11
[ 93.828103] perf: interrupt took too long (2527 > 2500), lowering kernel.perf_event_max_sample_rate to 79000
[ 121.937676] perf: interrupt took too long (3175 > 3158), lowering kernel.perf_event_max_sample_rate to 63000
[ 227.403295] perf: interrupt took too long (3973 > 3968), lowering kernel.perf_event_max_sample_rate to 50000
[ 315.181982] perf: interrupt took too long (4971 > 4966), lowering kernel.perf_event_max_sample_rate to 40000
Last edit: 06 Sep 2020 05:18 by turretbuddy2. Reason: forgot to mention the inclusion of files
06 Sep 2020 08:48 #181003 by PCW
Replied by PCW on topic Mesa 7i92 Intermittent Read Errors
These times/1.8GHz total to more than 1 MS
My guess would be that like most laptops there is
power management that cannot be disabled
You might try a 2 ms servo thread
The following user(s) said Thank You: turretbuddy2
06 Sep 2020 12:47 #181052 by turretbuddy2
Replied by turretbuddy2 on topic Mesa 7i92 Intermittent Read Errors
Thank you for the rapid response and i've made the change!
When calculating the times:
(read.tmax) -> 1522316 / 1.8GHz = ~0.846 ms
(write.tmax) -> 946588 / 1.8GHz = ~0.526 ms
(servo-thread.tmax) -> 1656028 / 1.8GHz = ~0.920 ms
Though the times are not explicitly over 1MS im guessing its close enough to matter? I'll report back later on the results.
Cheers
07 Sep 2020 16:18 - 07 Sep 2020 16:27 #181177 by turretbuddy2
Quick update, haven't been able to do extensive tests yet ,but the watchdog did bite followed by a read error.
Previously the watchdog was set to 5ms and has now been bumped up to 10ms.
p.s ran the machine again and the read error has shown itself again :evil:
Last edit: 07 Sep 2020 16:27 by turretbuddy2. Reason: update
  • Moderator
  • Moderator
07 Sep 2020 17:36 #181189 by tommylight
Replied by tommylight on topic Mesa 7i92 Intermittent Read Errors
Give us something to chew on, like:
what laptop, how much memory, did you disable everything possible in BIOS regarding power savings, speed step, hyperthreading, C states, etc. ?
07 Sep 2020 18:26 - 07 Sep 2020 18:33 #181193 by turretbuddy2
The laptop is a HP Pavilion dv6-2120tx
support.hp.com/au-en/document/c02033034
I believe it is stock besides replacing the hdd for a ssd.
In terms of bios it is minimalist and disabled everything I could. Didn't have power saving options I could disable.
I was able to get a hold of a dell optiplex 780 SFF. Going to swap in the ssd and install linuxcnc.
Last edit: 07 Sep 2020 18:33 by turretbuddy2.
25 Sep 2020 05:03 #183700 by turretbuddy2
Running linuxcnc on the new computer I have not experienced the read error once since the last post. It seems the laptop was not up to spec.
Thank you for the help
Moderators: PCW, jmelson
