7i92_7i76_7i74D.bit issue
- BeagleBrainz
- Visitor
12 Sep 2020 07:54 #181842
by BeagleBrainz
7i92_7i76_7i74D.bit issue was created by BeagleBrainz
Having an issue with the bit file, cut & paste from my session, just to see if things were work I loaded 7i92_7i77_7i74D.bit and all the serial ports on P1 showed up. 7i92.zip was downloaded today from here www.mesanet.com/software/parallel/7i92.zip
My 7i92 currently has 7i92_7i76_7i74D.bit loaded and the result is below.
rmurphy@bf20l-vario:~/Documents/bf20/Mesa/7i92/7i92/configs/hostmot2$ mesaflash --addr 10.10.10.10 --device 7I92 --write ./7i92_7i76_7i74D.bit
Checking file... OK
File type: BIT file
Boot sector OK
EEPROM sectors to write: 6, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
|EEEEEE
Programming EEPROM sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
rmurphy@bf20l-vario:~/Documents/bf20/Mesa/7i92/7i92/configs/hostmot2$ mesaflash --addr 10.10.10.10 --device 7I92 --reload
rmurphy@bf20l-vario:~/Documents/bf20/Mesa/7i92/7i92/configs/hostmot2$ mesaflash --addr 10.10.10.10 --device 7I92 --readhmid
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 8 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P1
1 17 IOPort StepGen 0 Dir/Table2 (Out)
14 18 IOPort StepGen 0 Step/Table1 (Out)
2 19 IOPort StepGen 1 Dir/Table2 (Out)
15 20 IOPort StepGen 1 Step/Table1 (Out)
3 21 IOPort StepGen 2 Dir/Table2 (Out)
16 22 IOPort StepGen 2 Step/Table1 (Out)
4 23 IOPort StepGen 3 Dir/Table2 (Out)
17 24 IOPort StepGen 3 Step/Table1 (Out)
5 25 IOPort StepGen 4 Dir/Table2 (Out)
6 26 IOPort StepGen 4 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort MuxedQCount 3 MuxQ-IDX (In)
12 32 IOPort MuxedQCount 3 MuxQ-B (In)
13 33 IOPort MuxedQCount 3 MuxQ-A (In)
Checking file... OK
File type: BIT file
Boot sector OK
|EEEEEE
Checking file... OK
File type: BIT file
Boot sector OK
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 3
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
- BeagleBrainz
- Visitor
12 Sep 2020 09:26 #181860
by BeagleBrainz
Replied by BeagleBrainz on topic 7i92_7i76_7i74D.bit issue
Downloaded new bitfile from here
www.forum.linuxcnc.org/27-driver-boards/...-7i74-bit-file#83085
Has the 7i92.zip updated ? Am I on the right track ?
- Clive S
- Thank you received: 486
12 Sep 2020 10:01 #181863
by Clive S
Rob. that post is from 2016, so it might be better to go to the Mesa site for the latest.
PCW will probably see this and give more info
Replied by Clive S on topic 7i92_7i76_7i74D.bit issue
- BeagleBrainz
- Visitor
12 Sep 2020 10:34 - 12 Sep 2020 10:43 #181868
by BeagleBrainz
I actually downloaded the 7i92.zip from the Mesa site today. The bit file I referenced in that post appears to be what is needed. At least doing a readhmid gives the pin output I was expecting to see.
md5sum a291ae7c2157d144b26cc5fad67357f0
Which has the incorrect bit file
appears to be different to
freeby.mesanet.com/software/parallel/7i92.zip
md5sum 7cbe387c1ff6c9251c36ef003c66319b
Which appears to have the correct bit file.
Last edit: 12 Sep 2020 10:43 by BeagleBrainz.
- Clive S
12 Sep 2020 11:14 #181872
by Clive S
Good does that mean you have it sorted?
- BeagleBrainz
- Visitor
12 Sep 2020 11:34 #181874
by BeagleBrainz
So far so good, I'll hook up the 7i74 & 7i83 and see how we go tomorrow.
Waiting on contactors, DIN Rail terminals & AC Line Reactor to come in so I can get the spindle wired up.
Then I can finish the upgrades to my table saw........which kinda lead to upgrading the spindle on the Mill.
Then.....hopefully the collars I ordered for my Myford ML7/Super 7 hybrid will come in and I can tick off another project. And then I can start making some stuff other than working on the machines..hahahaha well maybe
- Clive S
12 Sep 2020 12:22 #181879
by Clive S
I have a S7 as well. what do you mean by Super 7 hybrid. Pics
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- Visitor
12 Sep 2020 13:22 #181881
by BeagleBrainz
Started when I bought a ML7 bed off eBay. Then got a S7 headstock And Mk2 clutch, S7 tailstock and cross/compound slide.
The only issue is that to have the back gear installed I need to mod the bed. But I’m hoping the 1hp 3ph motor and VFD should bring things around.
Apart from the lead screw everything has been bought via eBay or RDG. Yeah I bought everything bit by bit. I think I’m a little crazy.
I don’t want to think how much postage has cost.
BTW the bed is a ‘53 model and just about spot on, I think the bed itself had very very little use.
- Clive S
12 Sep 2020 13:41 #181883
by Clive S
I have put a 60 slot encoder on the spindle it works a treat for threading.
I am thinking of changing the motor to a servo instead of the single phase one. I have a nema 23 on the lead screw and X screw. link to my nas photos.app.goo.gl/DNoUmQYVaNzo63yeA
- Thank you received: 5308
12 Sep 2020 13:43 #181884
Replied by PCW on topic 7i92_7i76_7i74D.bit issue
This is a bit mysterious since the bitfiles at www.mesanet.com and freeby.mesanet.com are identical:
peter@pcw-HP-EliteDesk-800-G1-USDT:~/Downloads/old/7i92/configs/hostmot2$ md5sum 7i92_7i76_7i74D.bit
2d3b556ac022961501c386ce54b98eea 7i92_7i76_7i74D.bit
peter@pcw-HP-EliteDesk-800-G1-USDT:~/Downloads/old/7i92/configs/hostmot2$ cd ~/Downloads/new/7i92/configs/hostmot2/
peter@pcw-HP-EliteDesk-800-G1-USDT:~/Downloads/new/7i92/configs/hostmot2$ md5sum 7i92_7i76_7i74D.bit
peter@pcw-HP-EliteDesk-800-G1-USDT:~/Downloads/new$ md5sum new7i92.zip
7cbe387c1ff6c9251c36ef003c66319b new7i92.zip
peter@pcw-HP-EliteDesk-800-G1-USDT:~/Downloads/new$ cd ~/Downloads/old
peter@pcw-HP-EliteDesk-800-G1-USDT:~/Downloads/old$ md5sum 7i92.zip
a291ae7c2157d144b26cc5fad67357f0 7i92.zipPlease Log in or Create an account to join the conversation.
Time to create page: 0.130 seconds
