Mesa 7I96 setup question
13 Sep 2020 02:47 #181967 by kbec
Mesa 7I96 setup question was created by kbec
I have most of the components I need. I was wondering if I can test just the Mesa card prior to hooking up the stepper drivers to see if it is working. I was hoping to take it one step at a time and do some sort of checkout every time I add a component.
Is that possible?
  • Moderator
  • Moderator
13 Sep 2020 08:51 #181994 by tommylight
Replied by tommylight on topic Mesa 7I96 setup question
Yes it is:
-wire the power to Mesa board
-wire a network cable from the PC to Mesa board ( not through a switch or a hub)
-set up the networking on the PC to be able to communicate with the Mesa board
-start pncconf and make a rough config with the settings you plan on having, later you can edit them again or make a new config.
The following user(s) said Thank You: kbec
Moderators: PCWjmelson
