Mesa 7i92 help
- prochj51
23 Sep 2020 09:49 #183475
by prochj51
Mesa 7i92 help was created by prochj51
I connected Mesa 7i92. I intend to use with BOB so I mesaflashed the 7i92_5ABOBx2D.bit in there.
I just wanted to verify that the communication is alright so I wanted to light up USER LED on 7i92.
I can load the card config.
then I light up the LED CR1
show pin shows that value is true, but the LED itself does nothing.
I also tried to toggle I/O but it does not seem to react.
Would anyone know what I do wrong?
Thank you.
Jiri
tom@linuxcnc:~/Desktop/7i92/7i92/configs/hostmot2$ halrun
halcmd: hostmot2
<stdin>:1: Unknown command 'hostmot2'
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="192.168.1.121"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
iptables: No chain/target/match by that name.
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:05:1b
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPortthen I light up the LED CR1
halcmd: setp hm2_7i92.0.led.CR01 trueshow pin shows that value is true, but the LED itself does nothing.
Thank you.
Jiri
- Thank you received: 5337
23 Sep 2020 10:21 #183481
Replied by PCW on topic Mesa 7i92 help
The default user LED function monitors received packets
(ping the card to verify)
- prochj51
23 Sep 2020 11:02 #183490
by prochj51
Replied by prochj51 on topic Mesa 7i92 help
When I ping it, it has some light up sequence.
How can I turn it on from halrun then?
23 Sep 2020 11:33 - 23 Sep 2020 11:41 #183496
You cannot, but you can setup the LEDs to temporarily follow the hal LED pins (until power cycle) via elbpcom:
elbpcom 01D914000000
You could also set this permanently by writing the correct EEPROM variable in space 2
Last edit: 23 Sep 2020 11:41 by PCW.
Time to create page: 0.069 seconds
