7i76 spindle control
6 years 1 month ago #184360 by centreline
Replied by centreline on topic 7i76 spindle control
Thanks all, good point on the flyback diode's for coil switched relays,
I should have said with a ssr rather than relay, as ordered some on a din rail mount so when they arrive I'll wire them in for all of my output switched functions as I can avoid using a flyback diode, and they're mostly more reliable.
6 years 3 weeks ago #185219 by centreline
Ended up buying a bank of din rail opto isolated relays, and allocated #1 to spindle direction as described, and the rest to suds/mist other duties and now everything is working as it should be.
6 years 2 weeks ago #185975 by summat
Replied by summat on topic 7i76 spindle control
Glad to hear the OP is sorted. There is another path that I went down which is to write your own HAL component to manage the logic - if I remember when I'm home from work I can post that if there's interest.
Moderators: PCW, jmelson
Time to create page: 0.229 seconds
