7i76 spindle control
6 years 1 month ago #184268 by centreline
Replied by centreline on topic 7i76 spindle control
I'm probably wrong about no Enable on the vfd on reflection, If removing the +24 -> LO+ jumper on the vfd itself disables the drive, I'll test, and if so I can enable the motion with the 7i76's ena outputs, and have a external relay driven by 7i76 DIR output to switch between forward and reverse with a single output.
6 years 1 month ago #184269 by tommylight
Replied by tommylight on topic 7i76 spindle control
centreline wrote: TB4 VFD
1 Spindle- ---> Com
2 Spindle out --> A/1
3 Spindle +v --> +10
4 NC
5 Ena
> ? (as per text, I have no enable and cant use it for reverse)
6 Ena +
7 Spindle Dir ---> Li1
8 Spindle Dir+ --> LO+
That is how it should be. Above you had Dir + and Dir- so that was wrong in many levels.
On your last post you are on the right track as that could work.
6 years 1 month ago #184273 by rodw
Replied by rodw on topic 7i76 spindle control
centreline wrote: .... and have a external relay driven by 7i76 DIR output to switch between forward and reverse with a single output.
I don't think you can use a single relay. M3 turns on the dir+ direction. M4 turns on the dir- direction. These two signals are managed by linuxcnc and will never be enabled at the same time. eg an M4 will cancel any active M3 and vice versa.
6 years 1 month ago #184277 by tommylight
But they will not cancel "enable", so his method should still work by making the default forward and when the relay is triggered to go in reverse, so the relay would be active only on M4.
The following user(s) said Thank You: rodw, centreline
6 years 1 month ago - 6 years 1 month ago #184279 by centreline
@rodw I'm not sure that is the case, as last time I used the mycnc board for spindle control, and I checked it now &it has two relays, one for enable and one for direction on it and four wires off to the parport, gnd, step, enable and dir.
I pulled my old hal file and in the gearchange component it reverses by changing the dir pin state and these are the only lines relating to rotation direction. ;-
net spindle-cw <= stepgen.4.dir => parport.1.pin-17-out
net spindle-cw => parport.1.pin-17-out
I could be wrong though, I thought last time that my drivers enable pin was held high in use and that turned out to be wrong. If I add the relay I'll just be back to how I had it before minus the enable relay and board to supply analog voltages and I can port the old config to new pin names.
Last edit: 6 years 1 month ago by centreline.
6 years 1 month ago - 6 years 1 month ago #184285 by PCW
Replied by PCW on topic 7i76 spindle control
Typically when a 7I76 is used with drives that have only FWD/REV inputs
(and cannot be reprogrammed for DIR/ENA), you can use a single SPDT relay
to steer the enable signal to FWD or REV depending on the state of DIR
So:
+24V --> RELAY_COIL+
RELAY_COIL- --> DIR+
DIR- --> GND
ENA+ --> RELAY_COM
ENA- --> GND
RELAY_NC --> FOR
RELAY_NO --> REV
This assumes the VFD inputs are active low.
The relay needs a flyback diode.
Last edit: 6 years 1 month ago by PCW.
The following user(s) said Thank You: centreline
Moderators: PCW, jmelson
Time to create page: 0.203 seconds
