7i77 and chines servo drive
6 years 3 weeks ago #185399 by bevins
Replied by bevins on topic 7i77 and chines servo drive
jazial wrote: Thanks,
Enable is already wired the way you describe, but I need drive error management (1 input for sensing, and 1 output for alarm reset)
I've started adding some relays, it should be fine
Thanks again
Which drives do you have? AASD drives?
6 years 3 weeks ago - 6 years 3 weeks ago #185482 by Todd Zuercher
I've not used those drives, I used some from Tecnik, Danhir, Yaskawa. And I've looked at manuals for lots of different drives when trying to help them here. Drive is enabled and when it faults, remove the enable signal, fault usually remains, reapply enable, fault is cleared and drive re-enables (unless the problem still exists, then it immediately faults again.)
Last edit: 6 years 3 weeks ago by Todd Zuercher.
Moderators: PCW, jmelson
Time to create page: 0.050 seconds
