- Thank you received: 183
BeagleBrainz wrote: That would only be an issue for inputs to the 7i76E.
As the optos are connected to an output controlling a relay as far as the 7i76E is concerned the load is an LED. Whether the photo transistor is NPN or PNP would not matter......that is assuming the relay board maker designed and made the board correctly.
All it should require if the circuit is designed for 12v and need to run it off 24v is a series resistor to suit.
