7i76e Bit File Problem
6 years 1 week ago #187218 by micknucam
PCW Supplied me with this bit file 7i76e_7i76x3D.bit the Pathpilot loads and runs the 7i76 part works fine have tested the encoder 0 and the 5 step gens. I then progressed to testing the encoders on the P1 and P2 Connectors.
I had a hunch they are all outputs so i tested each pin with a step gen and they work as outputs can some one check the bit file i think its not what i wanted.
[HOSTMOT2]
DRIVER=hm2_eth
BOARD=7i76e
DRIVER_PARAMS="board_ip=10.10.10.10 config=num_encoders=2 num_pwmgens=0 num_3pwmgens=0 num_stepgens=6 sserial_port_0=21xxxx"
BITFILE0=mesa/7i76e_7i76x3D.bit
DPLL_TIMER_NUMBER = 1
DPLL_TIMER_US= -100
This is what i was looking for
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
6 years 1 week ago #187223 by PCW
Replied by PCW on topic 7i76e Bit File Problem
Not sure what the issue is. This is what I get with readhmid
which looks correct to me:
mesaflash --device 7i76e --addr 10.10.10.10 --readhmid Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I76 FPGA Size: 16 KGates FPGA Pins: 256 Number of IO Ports: 3 Width of one I/O port: 17 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: DPLL There are 1 of DPLL in configuration Version: 0 Registers: 7 BaseAddress: 7000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: StepGen There are 15 of StepGen in configuration Version: 2 Registers: 10 BaseAddress: 2000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 3 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5A00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for on-card Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir TB2 4,5 0 IOPort StepGen 0 Dir/Table2 (Out) TB2 2,3 1 IOPort StepGen 0 Step/Table1 (Out) TB2 10,11 2 IOPort StepGen 1 Dir/Table2 (Out) TB2 8,9 3 IOPort StepGen 1 Step/Table1 (Out) TB2 16,17 4 IOPort StepGen 2 Dir/Table2 (Out) TB2 14,15 5 IOPort StepGen 2 Step/Table1 (Out) TB2 22,23 6 IOPort StepGen 3 Dir/Table2 (Out) TB2 20,21 7 IOPort StepGen 3 Step/Table1 (Out) TB3 4,5 8 IOPort StepGen 4 Dir/Table2 (Out) TB3 2,3 9 IOPort StepGen 4 Step/Table1 (Out) Internal 10 IOPort SSerial 0 TXData0 (Out) Internal 11 IOPort SSerial 0 RXData0 (In) TB3 18,19 12 IOPort SSerial 0 TXData1 (Out) TB3 16,17 13 IOPort SSerial 0 RXData1 (In) TB3 13,14 14 IOPort QCount 0 Quad-IDX (In) TB3 10,11 15 IOPort QCount 0 Quad-B (In) TB3 7,8 16 IOPort QCount 0 Quad-A (In) IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 17 IOPort StepGen 5 Dir/Table2 (Out) 14 18 IOPort StepGen 5 Step/Table1 (Out) 2 19 IOPort StepGen 6 Dir/Table2 (Out) 15 20 IOPort StepGen 6 Step/Table1 (Out) 3 21 IOPort StepGen 7 Dir/Table2 (Out) 16 22 IOPort StepGen 7 Step/Table1 (Out) 4 23 IOPort StepGen 8 Dir/Table2 (Out) 17 24 IOPort StepGen 8 Step/Table1 (Out) 5 25 IOPort StepGen 9 Dir/Table2 (Out) 6 26 IOPort StepGen 9 Step/Table1 (Out) 7 27 IOPort SSerial 0 TXData2 (Out) 8 28 IOPort SSerial 0 RXData2 (In) 9 29 IOPort SSerial 0 TXData3 (Out) 10 30 IOPort SSerial 0 RXData3 (In) 11 31 IOPort QCount 1 Quad-IDX (In) 12 32 IOPort QCount 1 Quad-B (In) 13 33 IOPort QCount 1 Quad-A (In) IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 34 IOPort StepGen 10 Dir/Table2 (Out) 14 35 IOPort StepGen 10 Step/Table1 (Out) 2 36 IOPort StepGen 11 Dir/Table2 (Out) 15 37 IOPort StepGen 11 Step/Table1 (Out) 3 38 IOPort StepGen 12 Dir/Table2 (Out) 16 39 IOPort StepGen 12 Step/Table1 (Out) 4 40 IOPort StepGen 13 Dir/Table2 (Out) 17 41 IOPort StepGen 13 Step/Table1 (Out) 5 42 IOPort StepGen 14 Dir/Table2 (Out) 6 43 IOPort StepGen 14 Step/Table1 (Out) 7 44 IOPort SSerial 0 TXData4 (Out) 8 45 IOPort SSerial 0 RXData4 (In) 9 46 IOPort SSerial 0 TXData5 (Out) 10 47 IOPort SSerial 0 RXData5 (In) 11 48 IOPort QCount 2 Quad-IDX (In) 12 49 IOPort QCount 2 Quad-B (In) 13 50 IOPort QCount 2 Quad-A (In)
6 years 1 week ago #187229 by micknucam
Replied by micknucam on topic 7i76e Bit File Problem
Hmm I’ll try that on my card I don’t know what the problem is either it when I connect a signal to the encoder pin 12 it pulls lots of current I’ve done this through a limiting resistor ! Do you think I have a jumper in the wrong place
  • BeagleBrainz
  • New Member
  • New Member
6 years 1 week ago #187232 by BeagleBrainz
Replied by BeagleBrainz on topic 7i76e Bit File Problem
Just a dumb question, but you did flash your card with the firmware.
When you run readhmid are you getting the same results as PCW ?
6 years 1 week ago - 6 years 1 week ago #187235 by PCW
DB25 pin 12? (This is _not_ HDR26 pin 12)
Note that bare FPGA pins are easily damaged by excess voltages and currents
( Simply shorting an I/O pin for frame ground in a system with high frequency ground
loop currents say from a VFD or step motor drive can destroy the input clamp diodes )
If you do connect external devices like encoders to the bare FPGA pins, you
should at have at the minimum, a series resistor to limit input currents (say 220 Ohm)
Last edit: 6 years 1 week ago by PCW.
6 years 1 week ago #187238 by micknucam
Yes
Moderators: PCW, jmelson
Time to create page: 0.350 seconds
