Mesa Terminal Block source
- BeagleBrainz
- Visitor
27 Oct 2020 12:55 #187446
by BeagleBrainz
Replied by BeagleBrainz on topic Mesa Terminal Block source
Thanks exactly what I was after.
I’d just like to add the support for Mesa products on this forum is far by the best I’ve ever seen from any manufacturer.
Cheers
Rob
Cheers
Rob
- Thank you received: 4154
31 Dec 2020 03:18 #193618
Peter, I'm a bit confused with the plug part numbers so a bit of help would be appreciated
I tracked the part down to this link
welink-sh.com/show_product.aspx?Products...ctsCateID=87&Order=1
And the red text takes you to this PDF
welink-sh.com/Upload/PDF/%E6%8F%92%E6%8B...73B3-09364357816.pdf
Which shows the green part number takes this form
F73-B-3-XX-Y0050
Where XX is the number of terminals (eg 08 = 8 pin)
But I don't understand how to specify Y which refers to the screw. I think it should be 1 but can you confirm?
I'd greatly appreciate your advice as I have a designer doing some work with me to interface with a 7i73 so I need to instruct him.
Replied by rodw on topic Mesa Terminal Block source
The parts we use are "Welink" brand as they are side stackable
and quite reliable.
example part numbers
F73-B-3.5.08P (8 pin side entry 3.5 mm pitch plug)
F83-5-3.5-02P ( 2 pin 3.5 mm pitch vertical header)
F73-B-3-XX-Y0050
- BeagleBrainz
- Visitor
31 Dec 2020 05:39 #193629
by BeagleBrainz
I managed to get the plugs from RS
RS Stock No. Qty Unit Price Goods Value Description
825-0840 25 $1.90 $47.50 Wurth Elektronik, 3631 3.5mm Pitch, 2 Way Pluggable Terminal Block
825-0852 10 $3.61 $36.10 Wurth Elektronik, 3631 3.5mm Pitch, 4 Way Pluggable Terminal Block
au.rs-online.com/web/p/pcb-terminal-bloc...enabled%22%3Atrue%7D
And the headers from Ali Express
www.aliexpress.com/item/32397432750.html...3.0.0.71814cc1l86aqn
These were the most compatible I could find. I used all the plugs but I have a headers left over if you want a sample or 2 of the 10 way ones.
31 Dec 2020 06:13 #193635
Rob, thanks. I made a note of them. Hopefully PCW will chime in. Seems the main thing is to choose a part number for the header with the correct pitch and the plugs can come from anywhere. There is an insane number of screw terminals required on my board.
- Thank you received: 7504
31 Dec 2020 06:18 #193636
Replied by tommylight on topic Mesa Terminal Block source
Building a Space Shuttle ?There is an insane number of screw terminals required on my board.
- BeagleBrainz
- Visitor
31 Dec 2020 06:59 #193644
by BeagleBrainz
These might save space if you aren't 100% sold on pluggable connectors. I've used them on a db-25 breakout board.
www.aliexpress.com/item/32959268216.html...1.0.0.252e4c4dymTl0w
- Thank you received: 5336
31 Dec 2020 09:53 #193661
Replied by PCW on topic Mesa Terminal Block source
Those PNs (without the extensions) are the exact numbers that I order with,
and appear on quotations from WELINK. Pretty sure you would be OK with their
defaults (Green and Y=1)
Time to create page: 0.287 seconds
