- Thank you received: 4153
Mesa Terminal Block source
- BeagleBrainz
- Visitor
5 years 10 months ago #193629
by BeagleBrainz
Replied by BeagleBrainz on topic Mesa Terminal Block source
I managed to get the plugs from RS
RS Stock No. Qty Unit Price Goods Value Description
825-0840 25 $1.90 $47.50 Wurth Elektronik, 3631 3.5mm Pitch, 2 Way Pluggable Terminal Block
825-0852 10 $3.61 $36.10 Wurth Elektronik, 3631 3.5mm Pitch, 4 Way Pluggable Terminal Block
au.rs-online.com/web/p/pcb-terminal-bloc...enabled%22%3Atrue%7D
And the headers from Ali Express
www.aliexpress.com/item/32397432750.html...3.0.0.71814cc1l86aqn
These were the most compatible I could find. I used all the plugs but I have a headers left over if you want a sample or 2 of the 10 way ones.
5 years 10 months ago #193635
Replied by rodw on topic Mesa Terminal Block source
Rob, thanks. I made a note of them. Hopefully PCW will chime in. Seems the main thing is to choose a part number for the header with the correct pitch and the plugs can come from anywhere. There is an insane number of screw terminals required on my board.
- Thank you received: 7491
5 years 10 months ago #193636
Replied by tommylight on topic Mesa Terminal Block source
Building a Space Shuttle ?rodw wrote: There is an insane number of screw terminals required on my board.
- BeagleBrainz
- Visitor
5 years 10 months ago #193644
by BeagleBrainz
These might save space if you aren't 100% sold on pluggable connectors. I've used them on a db-25 breakout board.
www.aliexpress.com/item/32959268216.html...1.0.0.252e4c4dymTl0w
- Thank you received: 5334
5 years 10 months ago #193661
Replied by PCW on topic Mesa Terminal Block source
Those PNs (without the extensions) are the exact numbers that I order with,
and appear on quotations from WELINK. Pretty sure you would be OK with their
defaults (Green and Y=1)
Time to create page: 0.888 seconds
