BOB does not generete step
  • veroski
  • veroski's Avatar Topic Author
  • New Member
  • New Member
28 Oct 2020 13:04 #187597 by veroski
BOB does not generete step was created by veroski
good evening, i am new to linuxcnc and i wanted to ask you for a hand
I tried to control the Nema 23 motor and the driver (online stepper dm542t) through the BOB bought here
www.amazon.it/Macchina-Incisione-Interfa...+%2Caps%2C188&sr=8-5
to create my .hal and .ini file I used the stepconf tool but when I have to test the engine, it doesn't run. so I performed these operations to resolve various doubts:
- I tried to control the driver with arduino by creating a pwm generator, and everything works
- i tried to check the output voltage at pin step and pin dir, on step pin there is not voltage and on pin pin there is.
- I tried to change parallel port to verify that the problem was not upstream
can you give me a hand to solve the problem? I don't know how to proceed anymore. thanks
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
28 Oct 2020 13:11 - 28 Oct 2020 13:12 #187599 by BeagleBrainz
Replied by BeagleBrainz on topic BOB does not generete step
Could you please attach your hal & ini files please.
Could you also give the output of
lspci -vn
just the info about the parallel port will be fine
dmesg | grep -i " par"
Also could provide some information about your computer, whether the Parallel Port is built on to the motherbord or a PCI - PCIe card and the version of Linuxcnc ?
Last edit: 28 Oct 2020 13:12 by BeagleBrainz.
  • veroski
  • New Member
  • New Member
28 Oct 2020 13:32 #187602 by veroski
Replied by veroski on topic BOB does not generete step
lspci -vn
10:00.0 0701: 14db:2121 (prog-if 02 [ECP])
Subsystem: 14db:2121
Physical Slot: 1-1
Flags: medium devsel, IRQ 20
I/O ports at 1100
I/O ports at 1110
I/O ports at 1108
I/O ports at 1114
Capabilities: <access denied>
Kernel driver in use: parport_pc
Kernel modules: parport_pc
dmesg | grep "parport"
[ 4.265354] parport0: PC-style at 0x1100 (0x1110), irq 20 [PCSPP,TRISTATE,EPP]
[ 4.362932] lp0: using parport0 (interrupt-driven).
[ 4.363049] parport1: PC-style at 0x1108 (0x1114), irq 20 [PCSPP,TRISTATE,EPP]
[ 4.473946] lp1: using parport1 (interrupt-driven).
the computer is hp compaq 6000
linuxcnc version is 2.9 pre
the parallel port is on pci
linuxcnc read my parallel port bcause when i run ptest.hal it does not give me anyone errors
  • veroski
  • New Member
  • New Member
28 Oct 2020 14:08 #187606 by veroski
i think that resolve this. i confirm that later
  • veroski
  • New Member
  • New Member
28 Oct 2020 15:06 #187615 by veroski
yes i solved, thanks for the help
  • BeagleBrainz
  • Visitor
  • Visitor
28 Oct 2020 15:32 #187622 by BeagleBrainz
So what did you do to resolve the issue, just in case anyone else has the same issue.
  • veroski
  • New Member
  • New Member
29 Oct 2020 04:01 #187665 by veroski
yes, it was just a connection problem. I remind everyone that to make the BOB work with the drive, you have to put the negative in common between the two systems
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
29 Oct 2020 04:08 #187667 by BeagleBrainz
Yes an easy one to make. ;)
Moderators: PCW, jmelson
