Mesa daughter cards: Parallel vs Serial
- mwinterm
- Thank you received: 13
11 Nov 2020 16:41 #189016
by mwinterm
Mesa daughter cards: Parallel vs Serial was created by mwinterm
Hello,
I'm retrofitting a Mikron WF41C from Heidenhain to LinuxCNC. I'm not yet clear regarding the right selection of Mesa Cards. There are basically endless options. However in many cases there is the option to use parallel or serial connected daughter-cards. What are the differences from a user-perspective. Which one is to prefer?
Regards,
Marc
Regards,
Marc
- Thank you received: 5336
11 Nov 2020 19:36 #189028
Replied by PCW on topic Mesa daughter cards: Parallel vs Serial
Typically , parallel breakout boards are used for high speed signals
like step/dir, PWM, and encoders and serial breakouts are used for slower
signal like general digital I/O for relay driving and limit/home switches etc
- mwinterm
12 Nov 2020 23:33 #189162
by mwinterm
Replied by mwinterm on topic Mesa daughter cards: Parallel vs Serial
Thanks for the feedback. I'm currently looking into the following configuration:
Does this look like a reasonable set-up to be operated by LinuxCNC?
Regards,
Marc
Computer Ethernet -> 7i80DB-25 -> 7i77 (Servo control, linear encoder, spindle on/off/dir)
-> 7i74 -> 7i70 (various inputs 24V)
-> 7i71 (varius outputs 24V)
-> 7i73 (some buttons like cycle, stop, spindle on/off, MPG for jogging etc)Does this look like a reasonable set-up to be operated by LinuxCNC?
Regards,
Marc
13 Nov 2020 00:17 #189166
It should be OK though a 7I92M will also work as the FPGA card
- Thank you received: 7501
13 Nov 2020 00:34 #189169
Replied by tommylight on topic Mesa daughter cards: Parallel vs Serial
I have used that same setup on several retrofits, but with 7i92 instead of 7i80
Computer Ethernet -> 7i80DB-25 -> 7i77 (Servo control, linear encoder, spindle on/off/dir) -> 7i74 -> 7i70 (various inputs 24V) -> 7i71 (varius outputs 24V) -> 7i73 (some buttons like cycle, stop, spindle on/off, MPG for jogging etc)
- mwinterm
13 Nov 2020 22:12 #189260
by mwinterm
Thanks for the feedback. Yes the 7i92 is all I need.
However, I just tried to order the cards at Mesa and the 7i71 is out of stock. When I called Mesa they told me that it would take 8-10 weeks until they have them again... Not so excited about that. Is hardware being out of stock for so long a problem that often occurs with Mesa?
Regards,
Marc
Regards,
Marc
13 Nov 2020 22:23 #189261
It does happen with some lower demand products as we occasionally
get larger orders that deplete our stock.
A 7I72 would be be a good replacement for the 7I71 if you can
use sinking outputs. Another option would be 2x 7I84s though this
would give you more inputs than outputs
(64 inputs and 32 outputs vs 48, 48)
- mwinterm
13 Nov 2020 22:44 #189262
by mwinterm
Sinking inputs do not make sense for me.
2x 7i84 would just work out as I need 31 outputs and 32 inputs. The 7i70 and 7i71 would just be nicer regarding the cabling as the Mirkon has a 37 pin D-Sub cable for all inputs and another one for all outputs (no x-cabling between the two cards and the two female D-sub 17 connectors).
Regards,
Marc
Regards,
Marc
13 Nov 2020 22:44 #189263
- mwinterm
13 Nov 2020 22:50 #189266
by mwinterm
...used them before but the 7i71 is also not available at the moment.
