INI conf for USC Pico Systems in MM
- edgemir
- Thank you received: 8
11 Nov 2020 14:32 #189033
by edgemir
INI conf for USC Pico Systems in MM was created by edgemir
Hi, I'm looking for an INI config to base on for my configuration in milimeters, last year I'm use the INI file inclueded in Linuxcnc 2.7 and works fine, but I always worked in metric system and I'll like to work in mm. I intended to adpat the file that I probed last year to my needs, but dont get it work.
thanks in advance.
thanks in advance.
- Thank you received: 7506
20 Nov 2020 13:00 #189912
Replied by tommylight on topic INI conf for USC Pico Systems in MM
Moved to "driver boards" category.
- jmelson
- Thank you received: 126
20 Nov 2020 13:09 #189914
by jmelson
Replied by jmelson on topic INI conf for USC Pico Systems in MM
There's really nothing special about a mm config. In the [TRAJ] section of the .ini file,
you set LINEAR_UNITS=mm, and re-scale velocities and step scales accordingly.
That's about all you need to do.
Jon
Jon
Time to create page: 0.081 seconds
