Board Selection: Mesa 7i95?
- Joz
11 Nov 2020 16:22 #189054
by Joz
Board Selection: Mesa 7i95? was created by Joz
Hello! First off, I am very new to LinuxCNC, so please be patient with me!
I'm building a CNC machine that will use closed-loop stepper motors and I want to also use linear encoders on all three axes to make the machine as accurate as possible. As I understand it, the 7I95 is the proper board for this, but I found an example of someone using a 7I96 + 7I85 to accomplish the same thing. I think the main difference here is price and latency, but I'm not sure if there's something I'm missing. Any and all advice would be greatly appreciated!
PS: The CNC will be 3 axes, with a potential 4th axis in the future, with no linear encoder
- Thank you received: 5337
11 Nov 2020 16:27 #189056
Replied by PCW on topic Board Selection: Mesa 7i95?
A 7I96+ 7i85 will work as will a 7I76E + 7I85
A 7I95 will work but I would not suggest it for a first time
LinuxCNC user since there is no graphic configurator
and it requires LinuxCNC 2.9
- Joz
14 Nov 2020 15:46 #189383
by Joz
Replied by Joz on topic Board Selection: Mesa 7i95?
Thanks for the info! Looking at these boards it seems like the 7I76 would be overkill for me. I just need the ability to connect my linear encoders and limit switches, and since the 7I85 will give me plenty of I/O I don't see an issue here, especially since they're both ethernet enabled cards. Although, would the 7I76E need the 7I85? It seems like it has enough I/O ports on its own, but I'm guessing I'm missing something. Thanks!
- Joz
14 Nov 2020 15:53 #189385
by Joz
Also, what is the correct way to power these boards? I know I read in another forum post that you can use 24v or 24v and 5v (which I guess you would do if you're worried about noise with the I/O?). But glancing through the manual I don't see rated amps anywhere. Thanks!
14 Nov 2020 15:57 #189389
The 7I76E can use 24V or a combination of 5V and 24V
The 7I95 is 5V only (though it has 5V to24V compatible I/O)
- Joz
17 Nov 2020 14:02 #189612
by Joz
Thanks for the info! Would the 7I76E need the 7I85 for this application? It seems like it has plenty of I/O on its own, but I'm guessing I'm missing something. Thanks!
Time to create page: 0.098 seconds
