7i96 bit file
- Hippy
14 Nov 2020 21:36 #189381
by Hippy
7i96 bit file was created by Hippy
Back again, i was told a longtime ago i was going to have to flash a new bit file so i could use THCAD's. Well i finally did flash but i wasnt paying attention and flashed the wrong bit file. Now my Z stopped working and its because i flashed something called xymod..What is the right bit file i need to flash?
- Thank you received: 5289
14 Nov 2020 21:53 #189386
Replied by PCW on topic 7i96 bit file
You can use the standard bit file if you have just one THCAD: 7i96d.bit
if you have more than one THCAD you would use: 7i96dpl.bit
The following user(s) said Thank You: Hippy
Time to create page: 0.630 seconds
