7C80 vs 7i96
16 Nov 2020 10:51 #189504 by PavelChekov
7C80 vs 7i96 was created by PavelChekov
Hello
i want to work with an raspberry pi 4
I want to use the 7C80 or the 7i96
Is there an different about the performance ?
Have someone work with the new 7C80 ?
16 Nov 2020 13:51 #189512 by PCW
Replied by PCW on topic 7C80 vs 7i96
There would be no significant difference in performance
A 7i96 would be easier to setup since there are 2 different GUI
configurators available. A 7C80 would need a hand edited hal/ini file
setup. You could start with a hal/ini file setup generated with one of
the GUI configuration utilities but a fair amount of hand editing would be needed.
17 Nov 2020 10:33 #189583 by snowgoer540
Replied by snowgoer540 on topic 7C80 vs 7i96
Just curious, what would be the main reason to choose the 7C80 over the 7i96?
17 Nov 2020 12:17 - 17 Nov 2020 12:18 #189586 by alkabal
Replied by alkabal on topic 7C80 vs 7i96
Hi
In my opinion the 7c80was mostly developed for RPI3 because does not support the ethernet realtime due to hardware design.
The Pi3 does not work with Ethernet Mesa cards as the ethernet is on the USB bus.
Last edit: 17 Nov 2020 12:18 by alkabal.
17 Nov 2020 13:14 #189588 by PavelChekov
Replied by PavelChekov on topic 7C80 vs 7i96
Ok, thank you very much !
17 Nov 2020 13:25 #189589 by snowgoer540
Hi
Makes sense! Thank you!
17 Nov 2020 15:09 #189596 by PCW
Much more I/O
Isolated analog spindle interface
Doesn't tie-up RPIs Ethernet interface
Supplies mechanical mount and power for RPI
Single 8V to 40V power supply
The following user(s) said Thank You: tommylight, snowgoer540, PavelChekov
Moderators: PCW, jmelson
Time to create page: 0.346 seconds
