mesa 7i80db
18 Nov 2020 15:28 #189680 by levis
mesa 7i80db was created by levis
Hi
Does anyone have High quality picture from both sides of mesa 7i80db board (or any other ethernet boards:7i80hd, 7I92, 7I93, 7I76E, ...)?
And any further information other than the user manual and software delivered by Mesa?
  • Moderator
  • Moderator
18 Nov 2020 18:24 #189704 by tommylight
Replied by tommylight on topic mesa 7i80db
Reverse engineering much ?
Would 64Mega Pixel pictures be good enough ?
Sorry for the sarcasm, but if you bothered to do some searching you would have quickly found out that one of the owners of Mesa Electronics is a very active member here and he is the best support on planet earth.
BTW, no amount of pictures will help with reverse engineering a 4 or 6 layer board.
Or you need them for something else ?
The following user(s) said Thank You: levis
18 Nov 2020 21:29 #189733 by PCW
Replied by PCW on topic mesa 7i80db
The FPGA firmware source is all supplied. If you look at the
constraints files you have a good idea what all the FPGA
connections do. If you ask nicely we can supply schematics.
The following user(s) said Thank You: tommylight, levis
19 Nov 2020 05:18 #189754 by levis
Replied by levis on topic mesa 7i80db
OK, you have answered yourself: No amount of pictures will help with reverse engineering a 4 or 6 layer board. Please don't worry:)
19 Nov 2020 05:19 #189755 by levis
Hi
Thank you for your quick answer, now I ask nicely for schematic please :)
  • Moderator
  • Moderator
19 Nov 2020 10:07 #189767 by tommylight
Hi
Much better ! :)
19 Nov 2020 14:12 #189780 by PCW
File Name: 7i92sch.zip
File Size:107 KB
The following user(s) said Thank You: Dorro1971, levis, Pegaskrs
19 Jan 2023 21:59 #262436 by Dorro1971
Replied by Dorro1971 on topic mesa 7i80db
Can't believe i kissed this!..
Thank you very much PCW.
My soldering station is warming up as I type!
Best,
Ian
Moderators: PCW, jmelson
Time to create page: 0.213 seconds
