Instal drivers for LPT port WHC WH38X
19 Nov 2020 08:38 #189782 by joseph
I'm new in linuxcnc. i have an problem to install the drivers for the LPT ports 2 pieces. I send the drivers please explain how i can install this drivers. thanks i use debian 9
19 Nov 2020 08:53 #189783 by PCW
Replied by PCW on topic Instal drivers for LPT port WHC WH38X
Have you tried Running linuxCNC without installing the driver?
In most cases hardware specific LPT drivers are not needed
19 Nov 2020 11:03 #189792 by joseph
Replied by joseph on topic Instal drivers for LPT port WHC WH38X
I tried it i find them both back when i use terminal and lspci -v but the add for both is not correct i got one as add e100 and the other d100 in any case thanks for the fast response
jeff
Moderators: PCW, jmelson
Time to create page: 0.070 seconds
