7i96 ethernet problem
5 years 11 months ago #190263 by PCW
Replied by PCW on topic 7i96 ethernet problem
Sounds like the EEPROM is bad/failed
I would send a email to Mesa and ask for a RMA# to repair/replace the card
4 years 9 months ago #233196 by Talla
Replied by Talla on topic 7i96 ethernet problem
How can i use setname ?
If i try i get an error.
command not found
or
no rigths
Greeting Peter
4 years 9 months ago #233206 by PCW
I get this: (on Mint 20)
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ cat setenv
export INTERFACE='elbp16'
export IPADDR='10.10.10.10'
export PROTOCOL='direct'
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ ./setenv
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ file setname
setname: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.4.0, with debug_info, not stripped
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ ./setname foobar
Old Name: 7I96
New Name: foobar
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ ./setname 7I96
Old Name: foobar
New Name: 7I96
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ md5sum setname
a94833ec586de99e4ef9dc04b8c2d0dd setname
4 years 9 months ago - 4 years 9 months ago #233211 by Talla
Can I download HM2UTILS somewhere?
cnc@cnc:~/Dokumente/setname$ file setname
setname: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, not stripped
maybe i have a wrong version
Last edit: 4 years 9 months ago by Talla.
4 years 9 months ago #233244 by PCW
Here is the 64 bit version plus  setenv
(you may need to change the IP address in setenv)
File Name: setname64.zip
File Size:794.98 KB
I can supply the hmutils source but I need to filter out some
customer proprietary stuff
The following user(s) said Thank You: Talla
Moderators: PCW, jmelson
Time to create page: 0.331 seconds
