Enhance 7i76e by shift register array
- mydani
- Banned
- Thank you received: 9
02 Dec 2020 16:24 - 02 Dec 2020 16:26 #190916
by mydani
Enhance 7i76e by shift register array was created by mydani
Hi all
I am wondering whether anyone had thought about enhancing the fpga with a dedicated serial shift register Interface, eg to have a cheap way of connecting loads of buttons or lights to the Mesa without the need to buy the more expensive boards
A cheap board with four shift registers is about three or four Bucks!
m.aliexpress.com/item/4000134105411.html...F.jpg_640x640Q90.jpg
Doing it via software would work and there is a component for that but it takes quite some runtime and is low update frequency.
Regards Daniel
Regards Daniel
Last edit: 02 Dec 2020 16:26 by mydani.
- Thank you received: 5337
02 Dec 2020 16:30 #190917
Replied by PCW on topic Enhance 7i76e by shift register array
For inputs you can use the inmux module. This uses external multiplexors
and has digital filter and MPG input options.
- mydani
- Banned
04 Dec 2020 15:10 #191073
by mydani
Replied by mydani on topic Enhance 7i76e by shift register array
The behavioral module isn't too difficult, esp. with the inmuxm as you proposed as guideline, but embedding it into the hostmot2.vhd is quite a task. I have to see whether this is possible for me in a limited time, otherwise I will see whether I can life with a slower update rate and use a SW implementation and faster servo thread instead.
Regards,
Daniel
Regards,
Daniel
