Mesa 7i76e: no board found
- Olivier_BXL-CNC
- Topic Author
5 years 10 months ago #191585
by Olivier_BXL-CNC
Mesa 7i76e: no board found was created by Olivier_BXL-CNC
Hi everyone,
I need some help getting my 7i76e up and running after a fresh install of the LinuxCNC live CD.
I tried reading through the different posts and sticky, but I'm stuck now.....
Any help would be highly appreciated.
My setup is as follows:
Debian 10 (Buster) with LinuxCNC 2.8.1
ASUSTeK P8H61 Motherboard
Intel Celeron CPU G1620 @ 2.70GHz
2x2Gb DDR RAM @ 1333MHz
Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
I did manage to disable IP v6 via the terminal:
sudo nano /etc/sysctl.conf
I added a line: net.ipv6.conf.all.disable_ipv6 = 1
I read about the IINTEL adapter issues, but didn't read anything about the Realtek adapters so I didn't do anything to that.
I have the 2 steady amber power leds illuminated on the 7i76e, as well as the green and amber ethernet leds.
The W3 jumper is set to UP.
Wicd Network Manager also shows me as "connected to wired network (IP:10.10.10.10)
I'm cabled straight to the Mesa, and don't have any other network adapter or wireless adapter installed.
I used PNCConf wizard to write 10.10.10.10 as IP address and set the same as fixed IP in the Wicd Network Manager.
Ping and Ifconfig give me the following:
olivier@LinuxCNC-G1620:~$ sudo ifconfig
[sudo] password for olivier:
enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.10.10.10 netmask 255.0.0.0 broadcast 10.255.255.255
ether ac:22:0b:c7:d8:fa txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 568 bytes 29532 (28.8 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 424 bytes 39054 (38.1 KiB)
TX packets 424 bytes 39054 (38.1 KiB)
olivier@LinuxCNC-G1620:~$ sudo ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.027 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.034 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.045 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.042 ms
^C
--- 10.10.10.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 71ms
rtt min/avg/max/mdev = 0.027/0.037/0.045/0.007 ms
When I try to launch LinuxCNC, I'm getting the following error message:
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Connection refused (-111)
./7i76_FIRST_machine.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./7i76_FIRST_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./7i76_FIRST_machine.hal:9: insmod for hm2_eth failed, returned -1
1238
Stopping realtime threads
Unloading hal components
Many thanks,
I'm sure I missed something during setup, but don't know what.
Best regards from Brussels,
Olivier
^C
1238
Many thanks,
Olivier
- Thank you received: 5334
5 years 10 months ago #191587
Replied by PCW on topic Mesa 7i76e: no board found
You have set your PC's IP address to the 7I76Es IP address, they must be different.
I would set the PC IP address to 10.10.10.100
The following user(s) said Thank You: Olivier_BXL-CNC
5 years 10 months ago #191588
Replied by tommylight on topic Mesa 7i76e: no board found
And stop using "sudo" for everything, it is not required.
Most of the time Linux will prompt when the "sudo" is needed.
- Olivier_BXL-CNC
- Topic Author
5 years 10 months ago #191593
by Olivier_BXL-CNC
Replied by Olivier_BXL-CNC on topic Mesa 7i76e: no board found
OK,
so it really was that simple (or stupid from me....)
I forced 10.10.10.100 in the network manager as PCW suggested.
This time I can read a good connection via masaflash and ping:
olivier@LinuxCNC-G1620:~$ ping 10.10.10.10
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.229 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.126 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.101 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.123 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.120 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.126 ms
^C
6 packets transmitted, 6 received, 0% packet loss, time 92ms
rtt min/avg/max/mdev = 0.101/0.137/0.229/0.043 ms
olivier@LinuxCNC-G1620:~$ ifconfig
bash: ifconfig: command not found
inet 10.10.10.100 netmask 255.0.0.0 broadcast 10.255.255.255
RX packets 7 bytes 652 (652.0
TX packets 48 bytes 2934 (2.8 KiB)
RX packets 22 bytes 2140 (2.0 KiB)
TX packets 22 bytes 2140 (2.0 KiB)
olivier@LinuxCNC-G1620:~$ mesaflash --device 7i76e --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I76
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Configuration pin-out:
MANY MANY PIN DATA HERE.....
I didn't spend time setting up all the axis, homing and limits yet, but at least I can now start LinuxCNC and move the axis.
That's already a great starting point.
Many thanks to both of you
Really appreciate your help.
^C
FPGA Pins: 256
IDROM Type: 3
5 years 10 months ago #191594
Nice, you are welcomed, always.
Time to create page: 0.054 seconds
