7i96 Working
- Hendrixx
- Thank you received: 27
20 Dec 2020 19:01 #192562
by Hendrixx
7i96 Working was created by Hendrixx
I'm building my first plasma table and it's been going really well. I cut and machined all my plates and mounts floating head, built out a solid frame. run all the wiring and installed Linuxcnc and was totally defeated getting anything to work until I sit down and started reading the documentation and actually understanding what I was doing. and I still couldn't figure it out so I basically threw every solution I could find at once. I'm not sure which solution tipped things in my favor but it's working now
So if I can help a little I will. My install of the 7i96 config tool never worked so I moved on, I started by installing network-manager
sudo apt-get install network-manager network-manager-gnome
sudo apt-get remove wicd wicd-gtk
then logged out and back in
using a USB wifi adapter
www.amazon.com/gp/product/B00JDVRCI0/ref...00_s00?ie=UTF8&psc=1
got it connected then right-clicked the network tool in the upper right and selected edit connections
found my wired connection and clicked the edit gear next to the + and - signs
go to the ipv4 tab select manual from the drop-down menu
click add
typed in the address*** 10.10.10.11 ***
press tab on my keyboard twice to move over to gateway
typed in the gateway as **** 10.10.10.1 ***
used my mouse to select the additional DNS area
typed in **** 10.10.10.1 ***
clicked the routes button and checked the box saying use the resources of the connection only
save logout out and back in
on the mesa board look for the jumper W5 and W6 the jumper on W5 should connect the 2 pins furthest away from the ethernet port and the w6 jumper should connect the 2 pins closest to the ethernet port, stagger them
now you can try pinging the card with
ping 10.10.10.10
it should return a number followed by the letters "ms" and repeat until you stop the program
now getting the board to communicate with your drivers,
I downloaded the support software
store.mesanet.com/index.php?route=produc...oduct&product_id=311
I installed unzip
sudo apt install unzip
I installed python 3.8
sudo apt-get install build-essential checkinstall
sudo apt-get install libreadline-gplv2-dev libncursesw5-dev libssl-dev \
libsqlite3-dev tk-dev libgdbm-dev libc6-dev libbz2-dev libffi-dev zlib1g-dev
cd /opt
sudo wget www.python.org/ftp/python/3.8.6/Python-3.8.6.tgz
sudo tar xzf Python-3.8.6.tgz
cd Python-3.8.6
sudo ./configure --enable-optimizations
sudo make altinstall
cd /opt
sudo rm -f Python-3.8.6.tgz
I installed mesa flash
sudo apt install libpci-dev pkg-config
git clone github.com/LinuxCNC/mesaflash.git
cd mesaflash
make
sudo make install
I unzipped the support software into my home folder named 7i96
I installed the dependencies for python
sudo apt install python3-pip python3-pyqt5 libpci-dev git
I tried to install the config tool
pip3 install git+https://github.com/jethornton/7i96.git
created a file in my home directory named .xsessionrc
by using
sudo nano .xsessionrc
copy this script into the editor
if [ -d $HOME/.local/bin ]; then
export PATH="$HOME/.local/bin:$PATH"
fi
ctrl x > yes > enter
opened pncconfig tool and unselect the spindle control
use whatever settings your setup calls for
when you get to the board select area pick the 7i96
change the address to be 10.10.10.10
apply the changes and set up your axis motors
and you should be good I'm sorry if I'm not able to help anyone further than this I'm just documenting how I got things running so I'll answer what I can but solutions to individual problems I cant give, thank you for your time and best of luck
click add
ping 10.10.10.10
I installed unzip
cd /opt
cd Python-3.8.6
cd /opt
cd mesaflash
make
sudo make install
by using
fi
- Thank you received: 7501
20 Dec 2020 19:47 #192567
Replied by tommylight on topic 7i96 Working
Oh well, sorry to see you had to endure and jump through all the hoops, but glad you got it working and thank you for getting all that in one place.
Now it is really simple to set up, but there is still way more outdated info on the net that cases such mess ups.
- hairyMug
- Thank you received: 3
05 Jul 2021 14:52 #213765
by hairyMug
Replied by hairyMug on topic 7i96 Working
THANK YOU! THANK YOU! THANK YOU!
- BigJohnT
- Thank you received: 994
05 Jul 2021 23:21 #213803
by BigJohnT
That makes me sad that someone had a problem with my tool but didn't say anything to me...
JT
Replied by BigJohnT on topic 7i96 Working
JT
Time to create page: 0.168 seconds
