Mesa Boards
23 Dec 2020 06:08 #192955 by Josemmrosa
Mesa Boards was created by Josemmrosa
I started retrofitting an HBM 45 profi manual desktop mill with step/dir servo drivers and TTL linear scales. I already have a 7i76+5i25 combo so I wonder if just adding a 7i85 board is enough to handle the system in closed loop. If that's fine, How should I wire them?, 7i76-5i25 via DB25 cable and 7i85-7i76 through TB1(7i85) Serial connector?. Could I also add a 7i73 also wired to another Serial port of 7i85?.
Thanks, José
23 Dec 2020 08:21 - 23 Dec 2020 08:23 #192960 by chris@cnc
Replied by chris@cnc on topic Mesa Boards
Hello Jose,
The 7i85 is connected to the extension connector P2 of the 5i25. You can find the correct firmware here
store.mesanet.com/index.php?route=produc...ct_id=55&search=5i25
Flashing the 5i25_7i76_7i85.bit file.
And it doesn't matter where you connect your 7i73. Try out where your first serial port is after flashing. The 7i76 has also one
chris
Last edit: 23 Dec 2020 08:23 by chris@cnc.
23 Dec 2020 09:11 #192968 by PCW
Replied by PCW on topic Mesa Boards
That bitfile has sserial channels arranged:
0 7I76 field I/O
1 7I76 serial expansion
2..6 7I85
23 Dec 2020 10:11 #192980 by Josemmrosa
Replied by Josemmrosa on topic Mesa Boards
Ok, understood. Thanks for such an early replies. I will purchase a 7i85 board with an expansion cable for 5i25.
I have other question about 3D CAD models of these boards. Could I get some .STEP file of them in order to design my own CNC panel?.
Moderators: PCW, jmelson
Time to create page: 0.123 seconds
