Connect MPG to 7i73
- Thank you received: 4154
27 Dec 2020 17:47 #193321
Connect MPG to 7i73 was created by rodw
I have a 5 volt MPG I want to connect to a Mesa 7i73 that has th efollowing signals
From what I can work out
it should be
A+ to 7i73 P1-11 (input 16)
B+ to 7i73 P12 (input 17)
But what about A- and B-? Do I just connect them to GND (7i73 P2-13)?
I'm doing this on a circuit board so I need to get it right first time.
A+
A-
B+
B-From what I can work out
it should be
- Thank you received: 5336
27 Dec 2020 17:53 #193322
Replied by PCW on topic Connect MPG to 7i73
The MPGs A- and B- should be left unconnected
if you ground them, you are shorting out the MPG signals
and may damage the MPG
27 Dec 2020 18:38 #193326
Thanks Peter. Much appreciated.
Replied by rodw on topic Connect MPG to 7i73
27 Dec 2020 18:46 #193327
And also if used as inputs P1-11 to P1-18 (inputs 16-23) should have a 10k pullup resistor to P2-29?
27 Dec 2020 18:51 #193328
And is a 10k pullup on inputs 0-7 correct when used as inputs (P2-3 to P3-10)
Sorry about all the questions.
27 Dec 2020 19:02 #193329
These do have 10K pullups to 3.3V (note that these inputs are 3.3V maximum input)
27 Dec 2020 19:04 #193330
You would need to add external pullups to these pins if used with switches
27 Dec 2020 19:10 #193331
Thanks I saw that about 3.3 V so am using 3.3 V from the 7i73 for everything except the Encoder which is using 5 v from the 7i73..
03 Jan 2021 06:07 #193944
So if the 7i73 needs to be powered directly, is that done through the RJ45 connector?
03 Jan 2021 06:16 #193945
Also Peter, what is a good resistor value for pullups on IN0 to IN7?
I was going with 10K which you use on some other pins but then I saw you had used 4.7k on P2.
Time to create page: 0.380 seconds
