HELP - I just fried a 7i76ED
  • htdave
  • htdave's Avatar Topic Author
  • Senior Member
  • Senior Member
05 Jan 2021 14:18 #194166 by htdave
HELP - I just fried a 7i76ED was created by htdave
Hi Guys,
I think I have just fried my 7i76ED.
I am still in the wiring / setup stage, and was just wiring up the Z limit switches.
I powered the board up, and it started smoking. I powered down ASAP, but looks like I have done some permanent damage.
Looks like a couple of ICs have burn marks, but I'm not sure what they are. They apear to be labelled U24 and U19.
I am still not 100% sure where the short was. The only difference from last working was I had wired Z limit switches - 1 wire to input and the other to field power.
The only other possibility is that the shielding on 1 of my cables accidentally touched the board and shorted everything out.
Does anyone in AUSTRALIA have a 7i76ED or 7i76ED board I could buy off them ASAP?
06 Jan 2021 04:10 #194199 by rodw
Replied by rodw on topic HELP - I just fried a 7i76ED
I have one in Brisbane but its not a D.
  • Moderator
  • Moderator
06 Jan 2021 05:06 #194202 by tommylight
Replied by tommylight on topic HELP - I just fried a 7i76ED
Before you get the new card, do check the wiring, again and again, make shure everything is OK before plugging the new one.
To much stuff burnt there but i did not have time to check what exactly.
06 Jan 2021 08:14 #194227 by Todd Zuercher
Replied by Todd Zuercher on topic HELP - I just fried a 7i76ED
Looks like some high voltage wire or something touched and shorted to the screw for TB2-pin6. (That or you really made hamburger out of it with a screwdriver.)
06 Jan 2021 10:27 #194243 by PCW
Replied by PCW on topic HELP - I just fried a 7i76ED
Yeah it looks like a high voltage (well 12V or more) got connected to the
7I76Es 5V rail
  • htdave
  • Senior Member
  • Senior Member
06 Jan 2021 13:17 - 06 Jan 2021 13:18 #194262 by htdave
Replied by htdave on topic HELP - I just fried a 7i76ED
Thanks rodw, I found one in WA yesterday, and it is on Startrack, so hopefully should have it by the end of the week
Last edit: 06 Jan 2021 13:18 by htdave.
  • htdave
  • Senior Member
  • Senior Member
06 Jan 2021 13:29 #194267 by htdave
7I76Es 5V rail
I hadn't noticed the mark on TB2-6. I just had a look at it, and it is only the top of the screw that is discoloured. Underneath looks brand new.
The only wiring change I had made was wiring in Z limit switches. These are an NC microswitch. I had them wired from 24V to TB6-14 and TB6-15. Should I have had them wired to 5V instead of 24V?
The other possibility is that the shield cable from one of my cables shorted out some pins on an IC - I will be insulating the ends of all cables before plugging the new board back in.
06 Jan 2021 15:18 #194286 by rodw
Was that from a distributor? I did not know we had any in .AU Please let us know.
Startrack express satchels are usually overnight ex WA to the eastern states.
  • htdave
  • Senior Member
  • Senior Member
06 Jan 2021 16:01 #194297 by htdave
No distributor. I found a lcnc user on facebook that had a spare board that I can have until I get a new one.
I was going to order a couple more off Mesa US, but he only had one in stock, so have ordered one for now.
I'm in Rural NSW, so overnight normally means sometime in the next 2-3 days :)
07 Jan 2021 01:30 #194328 by rodw
I know the feeling. I grew up in Western Queensland where we had one mail a week!
Moderators: PCW, jmelson
Time to create page: 0.396 seconds
