MESA 7i76e 3 Encoders on TB2/TB3
- mydani
- Banned
- Thank you received: 9
09 Jan 2021 09:52 - 09 Jan 2021 10:17 #194596
by mydani
MESA 7i76e 3 Encoders on TB2/TB3 was created by mydani
Hi all (PCW?
is it possible to attach 3 encoders with differential signals to pins on TB2/TB3 used for steppers?
No clue (or schematic) how these pins are connected electrically, but I assume no as one needs a differential input, the other one is a differential output.
Regards,
Daniel
Regards,
Daniel
Last edit: 09 Jan 2021 10:17 by mydani.
- Thank you received: 5337
09 Jan 2021 09:58 #194598
Replied by PCW on topic MESA 7i76e 3 Encoders on TB2/TB3
No, the 7I76/7I76E have only one encoder input,
and the step/dir pins are output only.
For low count rate applications you may be able
to use the MPG encoder input for 2 more encoders
(single ended though)
If you want more high speed encoder inputs on a 7I76E,
the best way is to add a 7I85,7I85S or 7I89
- mydani
- Banned
09 Jan 2021 10:18 #194604
by mydani
Replied by mydani on topic MESA 7i76e 3 Encoders on TB2/TB3
Thought so, thanks for the confirmation. I may just contact the encoders to P1/P2 temporarily using A,B,Z only until the 7i85 is there..
Regards!
Regards!
Time to create page: 0.188 seconds
