Bricked 7i92 :-( SOLVED THANK YOU)
- Dorro1971
- Thank you received: 16
17 Jan 2021 15:46 - 17 Jan 2021 18:28 #195710
by Dorro1971
Bricked 7i92 :-( SOLVED THANK YOU) was created by Dorro1971
Hi all,
I'm hoping someone can help me out ?..
I was playing around with pathpilot and it some how wrote the wrong bitfile to my 7i92...
Thinking it was an electrical fault I grabbed my second 7i92 and promptly bricked that as well.
Now,
I can download a bitfile to jt using xilinx impact tool and jtag (DLC10) ...and can happily ping it on192.168.1.121
UNTIL I REMOVE THE POWER then it looses it's memory.
I have used setname to call it 7I92 and that seems to work fine.
but if I try to use mesaflash (on windows) then all I get is device name invalid..if I move over to my Linux machine I cannot get passed network unreachable,...I was hoping I could use mesaflash to totally restore its memory...should this even work?
and if I remove the power its back to square one
Can someone give me a bit more info on where I need to shoot the bitfile?...
There are prom regions available but I have no idea if this is the right thing to do or what the details are..prom type size, width..etc...
So yeah, I seem to be up against it and could really use a bit of guidance....
Thank you in advance for a great service...and Mesa for a great product too....shame I'm the
Weak part in the equation!
Cheers
Ian.
Now,
Cheers
Ian.
Last edit: 17 Jan 2021 18:28 by Dorro1971. Reason: Spelling
- Thank you received: 5337
17 Jan 2021 16:08 - 17 Jan 2021 16:11 #195711
Replied by PCW on topic Bricked 7i92 :-(
You should be able to recover using either the ancient windows mesaflash
(which doesn't know about the 7I92) or the current Linux mesaflash
by programming the FPGA via JTAG and them using mesaflash
to write the EEPROM
The ancient windows mesaflash will work if you tell it that the card is a 7i80
and set these environment variables:
set protocol=direct
set interface=elbp16
set ipaddr=192.168.1.121
to write the EEPROM
set protocol=direct
Last edit: 17 Jan 2021 16:11 by PCW.
- Dorro1971
17 Jan 2021 17:08 #195718
by Dorro1971
Replied by Dorro1971 on topic Bricked 7i92 :-(
Hi PCW
Thank you for your advice.
i have carried out the instructions as you suggested....
both jumpers are at the bottom
I can ping the device and the four leds will change state
if I use scaneth i get device 7I92..
but if i enter setname 7i80 i get the following...
Old Name:
connection timed out.
my ip settings in windows are
tcp /ipv4
192.168.1.1
255.255.255.0
I could set the name earlier but ipconfig is not my strong suit..but if i can ping it and get a reply that should be it
i am trying not to get on your nerves but i'm a bit lost as to what;s up.
Thank you so far.....
Ian
Old Name:
tcp /ipv4
192.168.1.1
255.255.255.0
Ian
17 Jan 2021 17:48 #195722
Not sure why you would use setname at all
(Did path pilot change the card name?)
In any case the card name should be 7I92
I was just saying that the old windows mesaflash
doesn't care about the card name
so:
mesaflash --device 7i80 --write new7I92bitfile.bit
will work on a 7I92 (or 7I76E or 7I96 etc)
so:
- Dorro1971
17 Jan 2021 17:53 #195726
by Dorro1971
Thank you PCW
I sent a connection req.
Nothing sinister but any chance of a P.M.?
- Dorro1971
17 Jan 2021 17:59 #195727
by Dorro1971
NOW I SEE!...
I now have at least one functional 7I92!
Sorry to be a pita!
my previous post still stands by the way
But if not then thank you anyway, I know you do this for free and your time is valuable..I wanted to buy you a beer!.......
Best
Ian
Sorry to be a pita!
Best
Ian
17 Jan 2021 18:08 #195728
I try to avoid PMs because in general posts may
be valuable to many viewers. No beer required, its
a Sunday and I would rather do this than yard work...
The following user(s) said Thank You: Mike_Eitel, BigJohnT, pommen, Dorro1971
- Dorro1971
17 Jan 2021 18:14 - 17 Jan 2021 18:18 #195730
by Dorro1971
lol..
"Not sure why you would use setname at all
In any case the card name should be 7I92"
No i did that, i tried 5I25 in case mesaflash didn't know 7I92
Then changed it back to 7I92 when it made no difference..
now i cant change it at all BUT it reboots just fine after a power cycle so i think can work with that..
Sorry to sound like a dumb@ss but .......I'm still learning.
Thank you for your help, and a great product (despite my best efforts at sabotage)...
Ian
Ian
Last edit: 17 Jan 2021 18:18 by Dorro1971.
- Dorro1971
17 Jan 2021 18:26 #195731
by Dorro1971
"I try to avoid PMs because in general posts may
a Sunday and I would rather do this than yard work... "
Hell yeah!
But it's your Sunday not mine!
I greatly appreciate your help,. next time I'm in town the beers are on me!...covid permitting of course!
Hell yeah!
Time to create page: 0.114 seconds
