Mesa 7i97 pins
  • anfänger
  • anfänger's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Jan 2021 02:52 #196068 by anfänger
Mesa 7i97 pins was created by anfänger
Maybe my question ist a bit odd but I don’t know how to access the outputs on my 7I97
I stared LinuxCNC with the sample config for the 7i97 i found here.
I took a look at hals show to make me familiar with the pin names.
I found most I need but I can‘t figure out the pins for the output, for inputs there is something like muxin. Same for the Encoders and analog outputs. There is a big list of GPIO but how do I know wich are the outputs?
Am I missing something obvious here?
Thanks Patrick
21 Jan 2021 06:17 - 21 Jan 2021 06:31 #196078 by RotarySMP
Replied by RotarySMP on topic Mesa 7i97 pins
I found them on my 7i96 under "ssr", so maybe they are the same on the 7i97.
hm2_7i96.0.ssr.00.out-02
The GPIO pins are the ones of the P1 25 pin expansion connector
Mark
Last edit: 21 Jan 2021 06:31 by RotarySMP.
The following user(s) said Thank You: anfänger
  • anfänger
  • Platinum Member
  • Platinum Member
21 Jan 2021 13:31 #196134 by anfänger
Replied by anfänger on topic Mesa 7i97 pins
thanks that helped
Moderators: PCW, jmelson
Time to create page: 0.079 seconds
