Mesa 7I76E AXIS not resetting E-STOP
  • EragonPower
  • EragonPower's Avatar Topic Author
  • Senior Member
  • Senior Member
21 Jan 2021 05:22 #196074 by EragonPower
Mesa 7I76E AXIS not resetting E-STOP was created by EragonPower
Hello, i'm a novice with LinuxCNC and Mesa hardware, i've started playing around with CNCs for more than 3 years now, designing my own one and starting building it. I went through two controllers based on GRBL, but my project grown out of my hand, so as soon as i had money, i've pulled the trigger on a new Mesa 7i76e, but had problem as soon as i've wired it.
My new 7i76e just arrived, i've configured it paying a lot of attention for not scrawing something up, i've configured the eth0 with the right ip(10.10.10.10), and checked the connession with ping 10.10.10.10 and mesaflash, everything worked just fine, so
I went through PnCConf and configured almost anything i've needed, at that point i've tried to start AXIS to see if i messed something up in the process, everything started without errors, so i've tried to unlock the E-STOP button in AXIS(The one in the top left corner, beside the machine enable one) but that didn't work, it looked like AXIS froze, so i've tried to access one of the menu on top, everything worked just fine.
Is there something that i've overlooked somehow? Have i missed some configuration step?
I've tried again with a new PnCConfig installation, and the same exact problem manifested.
I don't really know that to do. Any suggestions?
21 Jan 2021 05:55 #196077 by Clive S
Replied by Clive S on topic Mesa 7I76E AXIS not resetting E-STOP
Can you post the hal and ini files from the config folder.
Also the results of your ping. What have you set your PC ip address to?
21 Jan 2021 06:33 #196079 by RotarySMP
Replied by RotarySMP on topic Mesa 7I76E AXIS not resetting E-STOP
Have you set up a physical E-Stop chain, and connected it to the 7i76E?
Mark
The following user(s) said Thank You: EragonPower
  • Moderator
  • Moderator
21 Jan 2021 06:44 #196080 by tommylight
Replied by tommylight on topic Mesa 7I76E AXIS not resetting E-STOP
PC should be set at 10.10.10.11 or anything above 11.
In pncconf do not set the e-stop pin, test and check if the rest works, then we can go back to setting the e-stop.
  • EragonPower
  • Senior Member
  • Senior Member
21 Jan 2021 11:14 #196109 by EragonPower
Replied by EragonPower on topic Mesa 7I76E AXIS not resetting E-STOP
The ping is between 0.132ms to 0.335ms
I can't upload the files because the pc that i'm running linuxcnc with is currently without internet access, but, as I said before, it's everything "stock" as made by PnCConf
  • EragonPower
  • Senior Member
  • Senior Member
21 Jan 2021 11:15 #196110 by EragonPower
The board has only a 7i75 connected to it, nothing more
  • EragonPower
  • Senior Member
  • Senior Member
21 Jan 2021 11:17 - 21 Jan 2021 14:33 #196114 by EragonPower
I've misswrote before, the pc is currently set to address 10.10.10.11 .
I've tried removing the E-STOP from PnCConf, and it's worked. Maybe the board is expecting an input or something else for resetting the E-STOP as it should be connected to it
Last edit: 21 Jan 2021 14:33 by EragonPower.
  • Moderator
  • Moderator
21 Jan 2021 11:28 #196117 by tommylight
Ice misswrote before, the pc is currently set to address 10.10.10.11 .
Nice. Yes it does expect an external control to get out of e-stop.
  • EragonPower
  • Senior Member
  • Senior Member
24 Jan 2021 09:44 #196418 by EragonPower
Thanks a lot!
Moderators: PCW, jmelson
