Mesa 7I84 problem
- tancorny
22 Jan 2021 05:02 #196196
by tancorny
Mesa 7I84 problem was created by tancorny
It's my first post on this forum - I want to say hello for everyone.
I'm retrofiting Biesse Rover 322 and I have problem with mesa cards 7i84. My configuration is 7i92, 7i77, 7i74 and 7i84 - 5 pcs. My problem is that I dont see 7i84 cards in my linuxcnc.
I've checked everything:
- vin power - conected
- field power A and B - conected
- cables OK and conected
- in hal file i have:
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000000"
- 7i92 card is configured on: 7i92_7i77_7i74D.bit file
- mesaflash readhmid give me the same results as pin file
- on 7i84 cards I've two yellow and one red led
I have no idea what I'm doing wrong... I need help!
- Thank you received: 7506
22 Jan 2021 05:08 #196198
Replied by tommylight on topic Mesa 7I84 problem
Post the readhmid results.
Are you sure the DB25 connectors are connected to the right equipment?
- tancorny
22 Jan 2021 05:22 #196202
by tancorny
Replied by tancorny on topic Mesa 7I84 problem
Connectors I conected first pin to first pin and so on. I make foto my conections.
- tancorny
22 Jan 2021 05:56 #196204
by tancorny
- tancorny
22 Jan 2021 06:03 #196205
by tancorny
readhmid results as attachment
22 Jan 2021 06:33 #196206
Everything looks OK there, so here is the loadrt line for such a setup
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=00000000 sserial_port_0=00010000 sserial_port_1=00200000"
The following user(s) said Thank You: tancorny
- tancorny
22 Jan 2021 07:01 #196213
by tancorny
I've changed loadart line and linuxcnc report errors:
Unknown parameter 'sserial_port_0=00010000 sserial_port_1=00200000'
22 Jan 2021 07:03 #196214
Replace the whole line, just copy and paste, do not edit the line
- tancorny
22 Jan 2021 07:16 #196222
by tancorny
Succes in 66%, cards on socket 1 and 2 works and I see pins but card on socket 0 stiil not work
22 Jan 2021 07:20 #196224
Do not use socket 0 ( or was it 8 ???? ).
Time to create page: 0.186 seconds
