hostmot2 encoder documentation
- Thank you received: 5282
23 Jan 2024 18:07 #291442
Replied by PCW on topic hostmot2 encoder documentation
Should be fixed now in master and 2.9.
- jtrantow
- Thank you received: 26
28 Jan 2024 00:57 #291777
by jtrantow
Replied by jtrantow on topic hostmot2 encoder documentation
What's the magical incantation to get this version? I installed from 2.9.2 iso. I updated the repo to search
deb www.linuxcnc.org/ bookworm base 2.9-uspace
deb [arch=amd64,arm64 signed-by=/etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg] www.linuxcnc.org/ bookworm 2.9-uspace base
deb-src [arch=amd64,arm64 signed-by=/etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg] www.linuxcnc.org/ bookworm 2.9-uspace base
I also tried deb buildbot2.highlab.com/debian/ bookworm 2.9-uspace
This got me updated from 6.1.0-16-rt-amd64 to 6.1.0-17-rt-amd64 and linuxcnc 2.9.2.106.g26e5d but it's still displaying the quad errors. I thought the linuxcnc or buildbot 2.9-uspace would give me all the 2.9 updates including this fix? Not sure what I'm missing?
28 Jan 2024 01:20 #291780
I don't know how old the buildbot image is but you may have to build
from 2.9 or 2.10 source to get the latest.
- jtrantow
29 Jan 2024 17:57 #291911
by jtrantow
I cloned master and built the RIP with your fix which works for the hal_encoder_test.hal script!
When I run the attached config, I still see the problem? (Simplified version of my mill.) I modified the hostmot version # and quad error string to make sure I was running the new hostmot and I am. So I think it's a step in the correct direction but not a complete fix.
- jtrantow
29 Jan 2024 20:19 #291929
by jtrantow
I couldn't figure out how to reopen issue #2680. So I opened a new issue in the tracker. I changed hm2_encoder_read_control_register() to clear encoder errors whenever they are disabled. It still needed the hm2_encoder_force_write(), but with this fix my config works fine. I'm not sure how much overhead the force_write() adds but for my config it doesn't matter since I'm off when this occurs.
I will push this change, but I wanted to make sure you saw it.
static void hm2_encoder_read_control_register(hostmot2_t *hm2) {
int i;
for (i = 0; i < hm2->encoder.num_instances; i ++) {
hm2_encoder_instance_t *e = &hm2->encoder.instance;
if (*e->hal.pin.quadrature_error_enable) {
e->reset_quadrature_error=0;
if(!e->prev_quadrature_error_enable){ // detect rising edge of pin quadrature_error_enable
e->reset_quadrature_error = true;
hm2_encoder_force_write(hm2);
bool state = (hm2->encoder.read_control_reg & (HM2_ENCODER_CONTROL_MASK | HM2_ENCODER_QUADRATURE_ERROR)) && e->prev_quadrature_error_enable;
if ((*e->hal.pin.quadrature_error == false) && state) {
HM2_ERR("Encoder %d: quadrature count error\n", i);
*e->hal.pin.quadrature_error = (hal_bit_t) state;
} else{ // quadrature error disabled, set reported error to 0
*e->hal.pin.quadrature_error = false;
e->prev_quadrature_error_enable = *e->hal.pin.quadrature_error_enable;
*e->hal.pin.input_a = hm2->encoder.read_control_reg & HM2_ENCODER_INPUT_A;
*e->hal.pin.input_b = hm2->encoder.read_control_reg & HM2_ENCODER_INPUT_B;
*e->hal.pin.input_idx = hm2->encoder.read_control_reg & HM2_ENCODER_INPUT_INDEX;
int i;
29 Jan 2024 21:03 #291935
Forcing a control register update every cycle on every encoder
almost any machine using Mesa encoders is really not something
that should be pushed.
Let me do some more investigation into why a existing error is not
cleared before the error mask is removed.
- jtrantow
30 Jan 2024 04:54 - 30 Jan 2024 04:56 #291957
by jtrantow
I agree. It will work as a temp solution for me as I always run with quad errors enabled and machine is off when it's doing the extra updates. I also had a bit & mistake that I cleaned up. I'll change the pull request to a draft.
Last edit: 30 Jan 2024 04:56 by jtrantow.
30 Jan 2024 15:45 #291989
Well...I cannot duplicate the error in either current 2.9 or master.
The only way I could generate the "error on error enable"
was to miss-configure the encoder DPLL timer so the read data
gets pipelined by 2 instead of the normal 1 relative to the error
clear.
I tested this cycle at least 20 times on both versions:
disable check
generate quadrature error
enable check
and was never able to generate an error on enabling the check.
clear.
disable check
enable check
- jtrantow
30 Jan 2024 17:04 #291995
by jtrantow
I will retest on my lathe config and try a fresh pncconf config on the mill.
- jtrantow
30 Jan 2024 19:43 #292007
by jtrantow
Thanks for you patience!
I went back and tested my lathe, mill, and a new config named quad. I build the code with your changes and the extra hm2_encoder_force_write() from the pull request. I test the lathe config on one computer, the mill and quad on another identical computer. These are old (2008ish) computers with dual core 3Ghz. The only changes I made to quad.hal were to comment out the extra x-pos-fb lines and add
net machine-is-on <= halui.machine.is-on => hm2_7i92.0.encoder.00.quad-error-enable
All three configurations fail with the master (and work with the extra force write) version of hm2_encoder_read_control_register(). I have a bad scale that's easy to create the quad error with. Every time I create an error while quad-error-enable is false, it will erroneously trigger when machine-is-on. (No reason to try multiple times to catch the problem on my setup.)
I have attached the quad files I am using.
Time to create page: 0.132 seconds
