Mesa 7i92 firmware change
- robertspark
- Thank you received: 216
30 Jan 2021 03:09 #197126
by robertspark
Mesa 7i92 firmware change was created by robertspark
how does one change the firmware on a 7i92 on Linux?
I have used the mesaflash utility (with the correct syntax) and it returns " firmware not found "( or something to that effect)
I downloaded the 7i92 firmware from the Mesa website in the zipped folder, copied the firmware files (*.bit) to the linuxcnc firmware folder
(from memory)
use/firmware/Mesa/ or is it hmot??
created a folder called 7i92 alongside the other Mesa firmware folders
and pasted the firmware into that folder
do I need to place the firmware file somewhere else so that the mesaflash utility can find it?
thanks
(from memory)
thanks
- bevins
- Thank you received: 338
30 Jan 2021 04:45 #197134
by bevins
Replied by bevins on topic Mesa 7i92 firmware change
You can put the 7i92 folder on the desktop if you want. open a terminal from there or from anywhere and cd into it.
Then cd configs/hostmot2
Make sure 7i92 is powered and connected to the computer via ethernet. Make sure you can ping it first.
ping 192.168.1.121 or
ping 10.10.10.10 or ping whatever you changed the ip to.
If you get a response then proceed to flash the firmware with:
you should get when it has completed::
mesaflash --device 7i92 --addr 10.10.10.10 --write 7i92_7i77x2.bit or
mesaflash --device 7i92 --write 7i92_7i77x2.bit you should get when it has completed::
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
- robertspark
30 Jan 2021 04:48 #197135
by robertspark
Replied by robertspark on topic Mesa 7i92 firmware change
thanks very much
- BigJohnT
- Thank you received: 994
30 Jan 2021 07:09 #197153
by BigJohnT
Replied by BigJohnT on topic Mesa 7i92 firmware change
I'm working on a tool to flash all the Mesa cards without having to open a terminal...
JT
JT
- robertspark
30 Jan 2021 07:40 #197155
by robertspark
thanks John
I am happy using the terminal and only by using it do I get better at it and understanding Linux (coming from a Windows click here, click there background... well getting more lazy)
+ thanks for sorting my drip feed of hardware orders (I noticed you not shipping direct to the UK at the moment, anything wrong with UK purchases? I know we are under "soft" lockdown but parcels are still being delivered largely undelayed).
Time to create page: 0.173 seconds
