Spindle direction on two pins with Mesa 7i76e
- EragonPower
- Thank you received: 4
31 Jan 2021 08:49 - 31 Jan 2021 09:14 #197219
by EragonPower
Spindle direction on two pins with Mesa 7i76e was created by EragonPower
Hello,
I've recently started to wire my new 7i76e into my new DIY CNC, built all by myself, today i was wiring the spindle when i saw that my VFD had two pins for the direction, one for Forward direction, and the other one for reverse, so at that point i stopped working on it as i didn't know how to connect it.
I know that the 7i76e can invert the direction pin for reverse, but, how can i configure it / wire it to work with two pin for spindle direction?
Thanks in advance.
EDIT: i know that I could set another pin in HAL to output two different signals for the spindle direction, but is there a better way?
Thanks in advance.
Last edit: 31 Jan 2021 09:14 by EragonPower.
- Thank you received: 5337
31 Jan 2021 12:14 #197233
Replied by PCW on topic Spindle direction on two pins with Mesa 7i76e
Many newer VFDs have the ability to run in either FWD/REV or ENA/DIR modes
so that is another option.
- EragonPower
31 Jan 2021 12:41 #197235
by EragonPower
Replied by EragonPower on topic Spindle direction on two pins with Mesa 7i76e
Sadly mine works only works with FWD/REV and the analog input, so i think I need to configure another pin in hal, or reconfigure the one configured for ENA/DIR to FWD/REV
- Mike_Eitel
- Thank you received: 183
31 Jan 2021 13:42 #197239
by Mike_Eitel
Replied by Mike_Eitel on topic Spindle direction on two pins with Mesa 7i76e
Make a small logic in hal
Enable and fwd go to pin vfd fwd
Enable and Not fwd go to vfd-pin rev
Time to create page: 0.134 seconds
