7i76 encoder single ended to differential
31 Jan 2021 16:49 #197222 by robertspark
7i76 encoder single ended to differential was created by robertspark
7i76 encoder inputs.
I know there is a jumper to change the encoder input from single ended to differential.... however.... I have a mixed signal....
I'd like to use the encoder input as differential.... (as I have a need for A+/A- for a thcad)
and I'd like to use the index as single ended for a SuperPID index (rpm pulse input 5v 0-30,000 rpm.....
hence would the index input be happy set on differential and fed a +5v / 0v input?
31 Jan 2021 17:53 #197226 by itsme
Replied by itsme on topic 7i76 encoder single ended to differential
I would use a rs422 to TTL converter Board for the Index Signal...
31 Jan 2021 18:10 #197231 by PCW
The 7I76E encoder signals are individually settable for single ended or differential
The following user(s) said Thank You: robertspark
01 Feb 2021 18:56 #197326 by robertspark
Replied by robertspark on topic 7i76 encoder single ended to differential
thanks.... read the manual moment....
head slap emoji!
(nice flexibility built in)
Moderators: PCWjmelson
Time to create page: 0.129 seconds
