For some reason mesaflash gave an error. This is from PP bot log file. Will this work?
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:03:00.0
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #5, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #5, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #6, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #7, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #12, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #7, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #8, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #12, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #8, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #13, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #9, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #9, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 027 (P2-07): StepGen #10, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 028 (P2-08): StepGen #10, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
