Add a second 7i73 >> solved<<
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Feb 2021 19:19 #197766 by tecno
Add a second 7i73 was created by tecno
Is it possible to daisy-chain a second 7i73 to already installed 7i73 ?
First one is in mode 1 and second needs to be mode 2
05 Feb 2021 21:43 #197782 by PCW
Replied by PCW on topic Add a second 7i73
You would need an additional RS-422 interface
  • tecno
  • Platinum Member
  • Platinum Member
05 Feb 2021 22:31 #197787 by tecno
Replied by tecno on topic Add a second 7i73
Can this interface be close to the other 7i73 = rj45 to interface and 2 new cables to 7i73's
06 Feb 2021 01:36 #197801 by PCW
Not sure I understand what you mean
  • tecno
  • Platinum Member
  • Platinum Member
06 Feb 2021 09:41 #197816 by tecno
7i76e + CAT6 (~5m difficult to add another) to 7i73 located in monitor stand.
So can I place RS-422 interface in monitor stand moving RJ45 to interface and add two new cables to each 7i73.
06 Feb 2021 11:26 #197824 by rodw
Replied by rodw on topic Add a second 7i73
You need to add another board to one of the 25 pin connectors that has a RS422 interface...
06 Feb 2021 12:06 #197826 by bevins
Replied by bevins on topic Add a second 7i73
Put a 7i74 then you can add up to 8 more cards via rs422, 7i73 being one option i believe. I use it alot for adding tons of I/O.
  • tecno
  • Platinum Member
  • Platinum Member
06 Feb 2021 12:08 #197827 by tecno
Rod/bevis are you saying that it must be connected to 7i76e P1 as P2 is occupied by 7i85s?
06 Feb 2021 12:21 - 06 Feb 2021 12:22 #197829 by bevins
One of the free ports. But you cannot connect it directly to one of those. Your existing 7i73 i assume is connected to the only rs422 port on the 7i76e so thats why you need the 7i74 if you want to connect more rs422 boards. 7i73 has a rs422 interface, so you need a card that has rs422 interface.
The ports are smart serial, so a 7i74 is an rs422 distribution card that you can put 8 rs422 devices on.
I am sure there are other ways to skin the cat, but i think this is the easiest and most versatile.
Last edit: 06 Feb 2021 12:22 by bevins.
  • tecno
  • Platinum Member
  • Platinum Member
06 Feb 2021 12:44 #197833 by tecno
OK thanks.
This will be a bit expensive and also PITA to install a new CAT cable.
Will try to get the PoKeys55 to work.
Moderators: PCW, jmelson
Time to create page: 0.133 seconds
