5i25-7i77 communication problem
25 Feb 2021 17:22 #200119 by skaggo
5i25-7i77 communication problem was created by skaggo
Hi, I cant get communication to the 7i77 board, it seems
5i25
firmware loaded and confirmed
7i77
TB2: 24v on pin 1 to 4, ground on 8, jumper in lh-position, i use the machines original PSU thru a thermal braker, messures 26,4V
W5 in lh-position
CR1 on
CR3 on
CR6 off
CR7 off
CR15 on steady
CR16 on
At startup i had encoder 0-2 and AO 0-2 connected, tried to desconnect them all, no difference. The 5v messures 4,6V without encoders, i have ordered a new 5V PSU but not yet tested, although the 5V-status LED is on so not giving it much hope..
I got readings from the encoders when i tried doing a pncsetup, but nothing on the PWM.
So, did i somehow break it, or have i missed something?
PS. disregard any spelling and gramatical errors, not my native language, if not obvious..
25 Feb 2021 17:49 #200121 by PCW
Replied by PCW on topic 5i25-7i77 communication problem
Sounds like you have W4 and W12 in the setup rather than operate position
26 Feb 2021 12:30 #200189 by skaggo
Replied by skaggo on topic 5i25-7i77 communication problem
Yeap, embarrassing simple if one knows what one is doing.
Many thanks, owe you a beer.
Moderators: PCWjmelson
Time to create page: 0.116 seconds
