configuracion mesa 6i24 en pncconf
- Ericcrinigan
25 Feb 2021 18:06 #200123
by Ericcrinigan
configuracion mesa 6i24 en pncconf was created by Ericcrinigan
Buenos dias, mi Nombre es Eric Crinigan. Estoy arrancando un proyecto con Linuxcnc y soy nuevo en el tema. compre una placa mesa 6I24 y una 7i33. para manejar 4 ejes con servomotor realimentado.
mi consulta es como configurar la placa 6i24 con pncconf ya que no aparece entre las opciones disponibles de firmware.
Gracias
Gracias
- Thank you received: 7400
25 Feb 2021 21:20 #200131
Replied by tommylight on topic configuracion mesa 6i24 en pncconf
Moved to "driver boards" section of the forum.
Translated via google:
Good morning, my name is Eric Crinigan. I am starting a project with Linuxcnc and I am new to the subject. buy a 6I24 and a 7i33 tabletop. to drive 4 axes with feedback servo motor.
my query is how to configure the 6i24 board with pncconf as it is not listed among the available firmware options.
- Thank you received: 4636
28 Feb 2021 23:41 #200485
Replied by andypugh on topic configuracion mesa 6i24 en pncconf
The 6i24 is the CPIe version of the 5i24. It uses the same firmware.
In fact a 6i24 will even be referred to as a 5i24 in HAL.
So select "5i24" and everything should work perfectly.
I wish that this was more obvious.
Time to create page: 0.073 seconds
